Author Topic: LC Pro Distributor timing problems  (Read 1685 times)
Junior84
  • Male Posts: 17
  • Member since May '06
« on: Dec 09, 2007, 11:35:50 AM »
I searched the forums but I wasn't able to find much help for this one...
Last night I installed LC's pro distributor with vacuum advance for the 22r.  the best I could get the timing was about 16 BTDC at around 1,100 RPMs. I test drove it, and the engine makes a clacking noise at low rpms as if  the distributor is out a tooth. I reinstalled it a tooth back, and the engine wouldn't start. So I reinstalled it again a tooth forward from the first time, and the engine runs weak, and the timing is at about 3 degrees past TDC, not the 8 to 12 before TDC, which is where its supposed to be with this distributor. I already have an LC adjustable cam gear installed at about 5 degrees advanced, and I'm wondering if that could be a problem.
Any help would be great, thanks
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
Re: LC Pro Distributor timing problems
« Reply #1 on: Dec 09, 2007, 01:07:31 PM »
Not sure why anyone would run aftermarket electronic equipment. You're asking for nothing but trouble.
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #2 on: Dec 09, 2007, 05:37:12 PM »
I believe lots of people run after market electronics without problems.  How many people on here have MSD?
I like to Drive!
Junior84 [OP]
  • Male Posts: 17
« Reply #3 on: Dec 09, 2007, 06:20:35 PM »
The Instructions that come with the distributor are different than the timing instructions on the LC website. According to the tech article on their site the rotor is supposed to point to the #1 spark plug wire before before installation. I'm gonna try this tonight
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #4 on: Dec 09, 2007, 06:31:53 PM »
If that doesn't work Junior, call John in the tech department at LC.  :thumbs:
I like to Drive!
Last post Oct 05, 2004, 05:45:19 PM
by burl4x4
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post Nov 27, 2007, 09:26:28 PM
by highridin4x4
Last post Sep 19, 2016, 01:30:50 AM
by Slabzilla
Last post Oct 09, 2018, 02:36:54 PM
by Yotaoverland
