So you bought a crate motor from LC.The bad news is that strokers don't like factory EFI. I wonder if LC told you this when you ordered that thing for $4-5k? There is an aftermarket (LC Engineering) solution - but it's another $1500 on top of it.
There are various ways to tweek the existing EFI, like manipulating the resistance of the engine temperature sensor... This is a patch, better than nothing, but I'm not sure it will work out well for ya..Get the timing worked out, all the engine codes straight, and then let's talk tuning...I'm in Austin, TX, btw..
im a weber guy myself but i have heard tell of a mod to the afm where you adjust it a couple of teeth just like the cam timing, do you know of this ?? Doug isnt it ??
ok, as you can tell, I have not had time to take off the cover. I am still having that same problem with keeping it started in the morning or after it has been sitting for a while. It will start just fine, run well for a few seconds..then die. It takes about 4 of these tries and then it will run fine (might have already gone over this, but just thought I would say it again). Some of my buddy's were saying there is a "flap" that keeps the gas from draining out of the motor...is that true? I started it for them and they said that it seemed to be a fuel delivery problem. What do you guys think? It does run fine after I start it up a few times.
so I gave it time today to build fuel pressure...I left the key to on, walked around to the fuel tank but could not here the fuel pump (I am not sure if it is like a chevy and has the same type of whining sound). I must have waited about 3-4 minutes. I turned it on and it did not die. All it did was rev to 2 grand (because it was cold) and then drop down to where it sounded like it was going to die...but it didn't. It did this about 4-5 times and then ran fine. Is there something wrong with my fuel pump? It is a pretty expensive part so how can I find out? Would a clogged fuel filter do this?
how much did you get your AFM for...is the price that is in the link the price you paid for yours? I was about to post how I should jump the fuel pump before I read your previous post . I actually wish the fuel pump is bad since it costs less than the AFM . I will DEFINITLY try jumping it tomorrow morning. It is getting worse...I feel it wanting to die every now and then on the highway. Also, is there anything on the web that will tell me the spots on the diagnostic box? I mean...the points that you told me to jump it at...which ones are they in the box?
so I jumped the fuel pump this morning...I could hear the pump but I had to crawl under the truck to hear it...should I have been able to hear it by just standing next to the truck? It started by having a whine that I could hear from kneeling next to my rock slider...but then it went away in about 2 seconds and got REAL quiet. I left the jumper on and the truck still had the same problem that I have without it...took 5 starts to finally get it to run this time (a little more than usual, but it ran fine after I started it numerous time...like it was doing before I jumped the fuel pump)...anybody know how I can put a video with a sound clip on the forum?
Started by Gewehr43 Engine
Started by blackdiamond General 4WD Discussion
Started by rscalmo Toyota Pickup/4Runner Tech 1979-95
Started by Junior84 Toyota Pickup/4Runner Tech 1979-95
Started by Yotaoverland Toyota Pickup/4Runner Tech 1979-95
