86 SAS swap Finished
Started by Doable, October 25, 2007, 09:02:02 PM
Doable
Well here goes I picked up an 86 4x4 extra cab and with parts laying around the yard and reading alot on this site here is what I ended up with It's still not finished but as my wife says it easy on the eyes as compared to when I first brought it home.
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
BSLCA.com
Doable
Found a donor truck for rust free body parts and bobbed the bed. Always wanted to do this I think this looks great on Toyota's.
BSLCA.com
Doable
Next came cutting the inside of the front fenders to make roon for bigger tires.
BSLCA.com
Doable
Then getting rid of the IFS and putting an 85 solid axle with Marlin Crawler hanger kit on the truck.
BSLCA.com
Doable
Built the front square drive shaft
BSLCA.com
Doable
While surfing on here I saw Hyena rear bumper and  :bowdown: thought I've got to make me one like that
BSLCA.com
Doable
 Finally got some vacation time from work and and was able to paint it all one color.
So we end up with what started out as a rusty rusty 86 4x4 with IFS and ended up with an 86 4x4 solid axle with 2wd sheet metal on it.
BSLCA.com
twistedtoy92
fatt_matt
Jeep
Doable
#9
Thanks, Was able to to do all the cutting off of the IFS and weldings on the SAS and painting at my buddy's shop  at his house , which was great of him to let me take up space there and work on my truck.
How the steering turned out with 86 rears up front
BSLCA.com
Doable
Got the sliders all welded up over the weekend and and good picture of the brace for the rear bumber.
Sliders made from 2 3/8" tubing
BSLCA.com
I like the cut on the wheelwells!  Too bad you couldn't find a good 4wd bed to use so you could have more bulge.
synwars
Quote from: Doable on November 11, 2007, 08:21:44 PM
That's a hefty looking bumper. Good job!
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
DTB
#14
Quote from: synwars on November 12, 2007, 12:19:41 PM
Hefty for sure! I would replace the wire stuff on the top with tube though and maybe some small gussets like this on the slider tube to keep help keep it attached to the plates...nice job  :biggthumpup:
86bobbedtoy
Doable
Thanks for the comments  :beer:  The bars for the sliders are only about six inches long, still putting some gussets would help strengthen it up. I know I'm far from finishing the welding I have to do on the truck.
BSLCA.com
ontherocks
4.7 t-case, welded rear, 33s, sr5 buckits, sas sooner than later. http://board.marlincrawler.com/index.php?topic=74399.0
awesome build man.
thanks for giving me the link.
i kind of like the front 2wd sheetmetal.
does the 4wd corner lights fit in them?
86bobbedtoy
I want to see some flex pictures.
Please
Cheesemaker
I need more info on what you did to clean and paint the frame?  I need to get my frame cleaned and treated.  I got some serious surface rust that is starting to pit the frame at the infamous spot.  The body mount in front of the fuel tank.  And some of the rear frame rails.  I want to stop it before it gets any worse.  Any info you got would be awesome!
Great job on the truck!  I liked the camo spot painting on the rust in the first pics!
Doable
cheesemaker , For the frame when I took off the bed and fenders to swap out all the rusty body parts I 1st pressuered washed all the frame let it dry then put some Rustolemun
rust inhabiter let it dry for a few days then two coats with a paint brush of industrial flat black. Will it last ? I don't know  but it's got to help and it was not expensive.
86bobbedtoy, I'm heading out for a long weekend to hit the trails and hopefully I'll get out and take some pictures  :gap:
ImahoToy85 , The front, rear tail lights all bolted along with the fuel cap everything was the same.
Got the cooler hooked up for the auto transmission  today and some "D" rings welded to a plate to fit under the factory bumper till I have time to build a new front bumper. but at least it gives me a platform to start with on the front.
BSLCA.com
skipnrocks
Looks good!!!  Those are the same d-rings I have...
WILLYNILLY
Rocksnail
 :clap: very clean build. keep up the good work. :beerchug:
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
TIMS89CRAWLER
hell yes bro she looks good!!! keep up the good work man and keep the pics coming
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
Bs85
are those just stock springs with 35s on the rear?
Doable
 Thanks for the complements . From the weekend trail ride.
The tires on the front only rub my shocks at the top alittle but they don't touch the fenders or bumper
Bs85 , I have 2" lift blocks with the factory springs till I put some Ford F-150 springs in the back. The truck feels very stable on the off camber stuff.
BSLCA.com
twistedtoy92
flexin like a champ man!!! nice work!
