The RE engine has much higher compression and weaker pistons than the RTE engine.
The RTE injectors also have a higher capacity than the RE's
I read that the bung is there on all 22r/22re blocks but it must be drilled
How does the throttle body plumb into this set up?
I has the SDS onboard computor system and am running low compression forged pistons already.
also remeber guys no warm shutoffs, let your tur bos idle down
sunn downer I like the top mount! what is it off of or is it a garrett or something?I like how you did your collant return to the radiator from the turbo. I bought a v6 radiator and had them weld on a bung like the stock turbo radiator. I parted out a whole 22rte and am swaping it in my 85 4runner. I am thinking about getting a ct-26. I just had the engine rebuilt. With stock turbo pistons bored +.5 and bugger stanless valves, coated bearings thick metal head gasket. heavy dity timing chane, preasure honed light portwork and all balanced, lso getting a dual friction clutch, want to get 440cc injectors with a supra afm, and am looking into a throttle body conversion. you truck looks sick that is what I am trying to do. you have a write up on here or pirate or anything?Jimmy g the ct 26 from the supras are nice in the seance you can drill out some holes and they fit on the 22rte manifold, however you just bought the ct20 do you have the manifold or are you making one? is the ct-20 rebuilt or what. they are notorious for going bad. a bigger exhaust might help. you need to keep them cool. also cheack the turbine housing that is where they usually crack. a new better made turbine housing made of a more durable casting is like 250 and an aftermarket part good luck.
I am not that familiar with turbos, so this will probably sound like a dumb question. What is the importance of a flex pipe in the exhaust system?
Started by colsoncj Parts For Sale
Started by dcg9381 Parts For Sale
Started by 85_4RNR Newbie Questions
Started by dh1 General 4WD Discussion
Started by 85yotapolo Engine
