Author Topic: my #1 plug doesn't fire, Whatup?  (Read 1256 times)
cobbrunner
  • Member since Oct '07
« on: Oct 18, 2007, 05:53:14 PM »
my truck(85/22re/4run) fires right up, but #1 won't fire. new cap, rotor, plugs, and wires.
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
Re: my #1 plug doesn't fire, Whatup?
« Reply #1 on: Oct 18, 2007, 07:29:09 PM »
No spark on that cyl, but the other have spark?
Have you moved the plugs around to see if the problem moves to a differant cyl? Try that with the wires too.
Did this start after changing the parts or before?
If it was before it could be a brain problem, but check the basics first.
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
« Reply #2 on: Oct 18, 2007, 08:18:41 PM »
If moving the parts around, as Willy Mammoth suggested doesn't change anything, do a pressure test on the cooling system. you may have a blown HG, wetting the spark plug.
SAVE TELLICO post 491
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #3 on: Oct 18, 2007, 08:57:37 PM »
Is there actually no spark coming through to the plug or does it just seem like it is not firing? It may be a lack of compression which could be a whole different issue, rings, seals, piston, head gasket, etc. etc. If the plug is getting wet enough to kill the spark you should be able to pull the plug and see it.
weirdtimes_7
  • Male Posts: 1,032
  • Member since Nov '06
« Reply #4 on: Oct 19, 2007, 08:22:41 AM »
pull the plug and have someone else turn your truck over... you should be able to see spark coming from the spark plug... if so, then your getting spark and there is a problem with your compression, if not, there is something wrong with your line
military_stang
:respect:
Last post May 14, 2005, 05:02:38 AM
by 79coyotefrg
Last post Jan 27, 2006, 02:28:18 PM
by BLACKDOG
Last post May 15, 2006, 09:22:25 PM
by Rocksurfer
Last post Nov 08, 2021, 10:16:03 PM
by Wainiha
Last post Jan 18, 2022, 06:06:17 PM
by Gnarly4X
