Check your TPS specs and clean your throttle body while you're in there.
the only way to get it off would probably be an easy out.
I would suggest doing that then.
Symptoms of a bad or mis-adjusted TPS include variying idle speed, hesitation while accelerating, poor fuel economy, and inabiltiy to correctly set base ignition timing.You don't think that it is worth checking?
ill call the guy that did the work and ask him if he can think of what he did to it or didnt do...
sounds good to me ill pay you in
Sweet. You better call me ASAP then. Im thursty
Started by 46&2 Chit Chat Camp
Started by doc83 Desert and Sand Life
Started by thegoofster21 Engine
Started by kneedownnate Chit Chat Camp
Started by ryantowry_81 Chit Chat Camp
