Author Topic: adjusted valves, now its louder?  (Read 3830 times)
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
« on: Oct 09, 2007, 10:51:02 AM »
i adjusted my valves a while back on my 22re.  i did it while the engine was cold, so i went a little loose with them.  it made alot of valve train noise, so finally i got around to adjusting yesterday with the motor warm so i could set it where it needs to be(.008-intake,.012-exhaust).  i put everything back together, fired it up, and it ran really smooth and quiet.  after it warmed back up again though, it started getting some loud rattling sound, almost like a bad tensioner or timing chain or something.  i pulled it back apart, checked everthing, and its all into spec.  fired it back up, and it does the same thing.  when i rev it up and let the rpms drop, it goes away for a few seconds, then comes back again.  i replaced the timing chain, tensioner, guides, and gears maybe 6-7k ago.  any ideas?  it never did this before i adjusted the valves.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
yotabj
  • Turtle Points: -15
  • Male Posts: 116
  • Member since Feb '05
  • MAD FLEX YO!!!!
Re: adjusted valves, now its louder?
« Reply #1 on: Oct 10, 2007, 09:29:01 AM »
I am going out on a limb but.....I have seen where people have tighten down the valve cover too tight and the rocker arms hit the cover......
Kind of a off the wall answer but I thought I would throw that in since no one was replying  good luck :_order:
'84  Truggy EFI swap ,5.29's Detroit,welded,Dual Ultimate Cases,22re,3 in. downey,4 in.Marlin Front springs on back  114 wb ,39.5 Rockers,30 Spline Longs
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Oct 10, 2007, 09:32:08 AM »
adjust the  exhaust to .010  and intake to .007    you dont get them as warm  when you are adjusting them  as they get at operating temps
superyota [OP]
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #3 on: Oct 10, 2007, 10:28:35 AM »
thanks guys, i'll try them both.  i'l keep you posted.
ABD Motorsports
#4475
KK6QDW
RN37DD
  • Male Posts: 742
  • Member since Apr '07
« Reply #4 on: Oct 10, 2007, 11:10:55 AM »
i had to replace the adjusting screws on one engine. the area that comes in contact with the valve was shattered. made it almost impossible to adjust.  and the engine would rattle like a diesel. changed them and the rattle went away.
Yota87Truck
  • Turtle Points: 2
  • Male Posts: 1,175
  • Member since Aug '06
  • Got Moab!
« Reply #5 on: Jan 05, 2008, 08:51:04 AM »
I'm having the same problems. I adjusted them to .008 and .012 and then it got louder. Then I tried loosening the valve cover. That didn't fix it. So I re-adjusted them to .007 and .010 and It got even worse, I have no clue why that would be.  Any Suggestions?
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #6 on: Jan 05, 2008, 09:08:20 AM »
Both of you need to check the adjusting screws as stated above. If they are worn out you will never get a true adjustment.
Yota87Truck
  • Turtle Points: 2
  • Male Posts: 1,175
  • Got Moab!
« Reply #7 on: Jan 05, 2008, 11:43:01 AM »
What will they look like if they are bad? And where is hte best place to get new ones? Dealership? Pick a Part?
« Reply #8 on: Jan 05, 2008, 12:50:15 PM »
ive found  good ones at the  pick n pull but  only in wrecks,
new  oem  would be best
i also question your tensioner,  where did you get it??   it  sounds  like its only  "tensioning"  when you  get  above idle  which is BAD
RynothealbinO
  • Male Posts: 141
  • 36's on no lift!
« Reply #9 on: Jan 05, 2008, 04:00:05 PM »
What valves are you guys having problems with?  I have had problems with the number 2 and 3 intake valves because the plastic spacer was worn down to the point that the adjsters were touching less than half of the valve stem.  I know you can also get adjusters from LCE or engnbldr.
Trust in the LORD with all your heart and lean not on your own understanding, in all your ways acknowledge him and he will make your paths straight.  Proverbs 3:5-6  Don't let anyone look down on you because you are young, but set an example for the believers in speech, in life, in love and in purity.  1 Timothy 4:12
superyota [OP]
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #10 on: Jan 07, 2008, 03:07:30 PM »
mine ended up being the valve cover gasket.  it was squashed down too far, and even if i loosened it up, still too far.  got a new one, and the problem is gone.
ABD Motorsports
#4475
KK6QDW
OOPS
  • Male Posts: 2,561
« Reply #11 on: Jan 07, 2008, 03:33:07 PM »
They will have a groove worn in them. If it were mine I would source new ones.
hotrod
  • Turtle Points: 15
  • Member since Nov '07
« Reply #12 on: Jul 06, 2009, 11:51:48 AM »
i know this is an old thread, but better than startin a new one i guess, does this sound anything like yalls valves? dont really wanna cough up 40 bucks for new adjusters but itd be an easy fix i guess. 22r valves and rockers, engnbldr cam, 20r head on 22r. http://s581.photobucket.com/albums/ss256/hotrod83yota/?action=view&current=100_4612.flv
David - 83 SR5 longbed, 20/22r, locked f/r, w-56, 33 km2
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #13 on: Jul 06, 2009, 12:31:03 PM »
 :shhh:
superyota [OP]
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #14 on: Jul 06, 2009, 01:51:11 PM »
wow! thats a lot louder than mine was.  i had it sound like that once after i changed my timing chain.  ended up the sound was coming from a bolt that i installed in the oil pump wasn't the right bolt for the hole. was hiting the links on the chain and sounded just like that.  if you have taken the timing chain cover apart, look into it, that might be the sound your hearing.  keep posted.
« Last Edit: Jul 06, 2009, 02:08:26 PM by superyota »
ABD Motorsports
#4475
KK6QDW
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #15 on: Jul 06, 2009, 01:54:46 PM »
I had good luck talking with the tech guys at MC and ToyConnection. Both had relevant points in problems that I have had in the past. Seems like they are eager as we are in trying to get our rigs up and running.
hotrod
  • Turtle Points: 15
« Reply #16 on: Jul 06, 2009, 06:28:21 PM »
i might have to give either marlin or toy connection a call tomorrow. im pretty sure i got the oil pump bolts right this second go around. that video was from my first attempt at the timing stuff. ill get another video tonight. it doesnt sound like the chain rubbing on anything anymore which is very good.
« Reply #17 on: Jul 06, 2009, 07:52:09 PM »
you might need to find a 22RE valve cover  they are slightly taller, thats what i have on my engine,  the regular 22R cover hit the rockers
hotrod
  • Turtle Points: 15
« Reply #18 on: Jul 06, 2009, 08:13:47 PM »
i might try unbolting it and raising it while running to see if it goes away. i tried running it without it on once to find a sound. wont ever do that again! freakin dual row chain flings some oil thats for sure.
hotrod
  • Turtle Points: 15
« Reply #19 on: Jul 07, 2009, 01:44:11 PM »
got a RE valve cover and some good looking adjuster screws while i was in there. one question though, how do you have your throttle cable hooked up? i see you have a weber which probably makes a difference
Tim
  • Turtle Points: 69
  • Male Posts: 92
  • Member since Oct '06
« Reply #20 on: Jul 12, 2009, 12:16:51 PM »
adjust them when hot
« Reply #21 on: Jul 12, 2009, 12:20:25 PM »
my 79's cable is attached to the passenger side rear valve cover stud
earlier in this thread someone posted about a plastic spacer on the rocker assembly,  in this case go find a 20R at the wrecking yard and get the entire rocker assembly and get the spacers, rods, whatever you need from them
hotrod,  you will need to cut part of the tin splash guard (keeps the oil from slinging out if you remove the oil fill cap) out of the valve cover mine hit my timing chain till i fixed that
« Last Edit: Jul 12, 2009, 12:26:22 PM by 79coyotefrg »
hotrod
  • Turtle Points: 15
« Reply #22 on: Jul 13, 2009, 08:47:52 AM »
ya, i got the throttle figured out and then threw it on and it started making a weird timing chain sounding noise, so i pulled it back off and it was gettin into that splash guard as you were saying. so put the 22r cover back on for now. i dont think its tapping, its pretty loose though. ill proabably clean up and paint the 22re cover and cut out that splash guard and run it.
about that plastic spacer, where is it? im running the complete 22r rocker assembly, dont think i missed anything unless something changed between the 20r and 22r heads?
Halladay
  • Member since May '09
  • HALLADAY
« Reply #23 on: Jul 13, 2009, 09:07:53 AM »
i did mine first at .008 .012 then it was noisy then did .007 .010... still noisy so i said screw it and adjusted it .006 .009 and it shut them right up. then one of my buddys told me you have to adjust them differnt if you have a aftermarket cam...
hotrod
  • Turtle Points: 15
« Reply #24 on: Jul 13, 2009, 11:05:02 AM »
dang, well i just sent engnbldr an email, hopefully his cam is supposed to be .006 and .009 like yours and thatll quiet them down alittle. people think its a diesel right now.
edit: ted recommended .007 intake and .009 exhaust
       gonna go try that out and see what happens!
« Last Edit: Jul 13, 2009, 11:19:59 AM by hotrod »
Halladay
  • HALLADAY
« Reply #25 on: Jul 13, 2009, 12:29:35 PM »
yea if you dont have a stoc camshaft this is your problem cause i had the same one. its just going to take time and play with the feeler gauges and see what shuts it up. let me know what happens
hotrod
  • Turtle Points: 15
« Reply #26 on: Jul 13, 2009, 01:03:33 PM »
just put them to .007 and .009 and they quieted down a ton. still not completely silent but alot better than it was. its about the same as it was with stock motor. might drop them down to .006 and .008 when i put on the new valve cover but i dont want to burn up a valve on a brand new motor, or any motor for that matter.
Halladay
  • HALLADAY
« Reply #27 on: Jul 13, 2009, 03:12:49 PM »
ya for sure just keep playing with them
Last post Mar 31, 2004, 09:55:48 PM
by Marlin
Last post Mar 13, 2005, 06:51:42 PM
by 79coyotefrg
Last post Mar 14, 2006, 01:51:37 PM
by 79coyotefrg
Last post Jun 02, 2007, 05:59:40 AM
by RN37DD
Last post Aug 18, 2007, 03:11:45 PM
by lilbuddy
