I'm putting an Aussie together now, everything checks out so far. clearance is tight. .145. spec's are .145 t0 .174. guess the install grease might might be taking up .002 or so. any thoughts on this?
My thoughts are: I never checked this on the front or rear locker and both are still performing flawlessly.
I'm thinking about one up front now. How much did this reduce your steering or did you not really notice?
with an aussie? not much at all, im happy with the turning.
didn't notice.
ya its fully fine the clicks are normal thats how its designed. i remember when i first installed mine i thought the same thing but i seem to find that once it breaks in it quiets down.
i can see why once you put one in you want to put another up front.
yeah, you should hear em in a rear on pavement.
I've got 500 miles on mine and it's getting quieter all the time. mines a DD and it doesn't bug me at all. but i drive on dirt back roads almost every day and it's nice not to have to shift to 4wd when i go in the rough. now if someone was to give me an e-locker or air locker for only $250 I'd dig that too!
Just don't dump the clutch while turning a tight corner at a high rate of speed --BigMike
what do you mean by dumpin the clutch?
no. i think you'd really have to try to break an Aussie. by dumping the clutch, i think he's talking 4000rpm plus on dry pavement, while your doing a hard turn.
Impact gun...im assuming you dont have that either....you know anyone that has the right tool for the right job?
iv done this many times and never used power tools or anything special just use this cinder block...http://www.demxx.com/images/standardblockB2_th.jpg throw a towel on it if your worried about the bearing staying clean and drop the spider gear/carrier end into one of the holes, then all u need to do it brace the block with your other foot and then you can just use a cheater bar on a ratchet and your good to go.
Started by Skinny_Pedal Engine
Started by h0nke Engine
Started by mudaddict Parts For Sale
Started by Mac5005 « 1 2 » Engine
Started by dat82toy Parts For Sale
