tell me what you think?
Started by ghetto_wheeler, September 26, 2007, 01:01:11 PM
ghetto_wheeler
someone came and asked me last night if i wanted to trade my pretty much stock ifs 87 toy ex cab for a 81 toy 12bolt and 44 front and rear i dont know much about axles but arnt those worth more than my truck i got for $900 should i do it pretty much for the axels i guess he still using his stock stearin so no high stear both trucks are in ok condition for there age i guess he just wants it cause the newer body style so tell me what you think ya or na
1992 toy single cab built very little highsteer on 39.5s
39.5 irocs for sale or trade...pm me
Hammerhead
I wouldn't...
12 bolt is worth about $100 and the 44 is worth just a bit more.  I wouldn't buy it just for the axles.  Only buy it if you feel it would be a better platform for the build you have in mind and only if it is in as fair condition as yours...
my 2 cents worth...
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
ghetto_wheeler
wow i thought those axels were worth tons i hate the body style so i guess it would be better to stick with what i got
Hammerhead
If it were a 14 bolt and a Dana 60 then I'd say jump on it...
'88 X-cab, V6
iNfErNaL
I DEFINATELY say stick with what you got.More room,Fuel injection and a nicer body.The 12 bold aint worth a :pokinit: IMO and a 44 is just 1 notch above the 12 bolt,plus it's carburated.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
yota_krawler
don't do it. listen to infernal he is smart when it comes to this :pokinit: so don't do it, you just want straight axle and you had a 83 and you hated it cause the body and the carb.
red
the 12 bolt is slightly stronger than a gm 10 bolt so with a v8 its good for up to 36" tires with a locker. the dana 44 front (might have been a gm 10 bolt front, looks very similar) is good for 35" tires with a v8. not the best axles, but they're very common and the front axle can be upgraded to about the same strength as a dana 60 for less than a dana 60 would cost.
if you dont like the carb and the body style of the older truck stick with your 87. those axles under that truck are cheap, 100 bucks hub-hub is about average.
read and comment :whip:
USAF EOD tech
