35's with 4 inch lift or 37's with 5 inch lift
Started by -Matt-, August 30, 2007, 11:23:13 PM
havik
Quote from: Volcom on September 09, 2007, 06:50:00 PM
I've got 5" of lift and I rub my worn out 33's (that only measure out to 31" tall) big time on the rear fenders on my 4Runner.  I do get quite a bit of rear flex but there's no way I could run anything taller without some major triming.
time to bust out the big hammer and a sawzaw or diegrinder.
got another 85 runner. build coming soon!!
havik
also the 4" lift kit is more than 4" when you factor in the shackle and if you do a new front x member and when you move your spring hanger up it gets lower on the frame which also probably gives a little more lift
Shoopdog29
I have the 4's all the way around on my 4runner with 37 inch tires. The front rubs when fully flexed but a 10lb sledge fixed it pretty well (still rubs a bit though). It sits pretty level with the top on and the winch bumper in the front.
Volcom
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
