gears gears gears
Started by 1983 yota, August 29, 2007, 04:30:42 PM
1983 yota
I am new at this rockcrawling buisness but very excited to build my first. I hear the 5:29 gears with a locker is the way to go. I dont know what other combo would be better? Do you? Whats the comparison to a true spool locker or welded spider gears? theres gotta be a reason there 300.00 an axle?
are you building a truck to DD  and  rock crawl??  if so  you want selectable,  elocker or a ARB air locker
if its a trail only truck  SPOOL
Shamb
gear selection depends upon what size tire you plan on running. Typically a 5.29 in the diff = 37" tire... maybe 35"
85yodaon33s
I'm running 35's on my 81 with Detroit lockers front and rear and i think it is a little to low geared for dd conditions
1983 yota
My truck will be trailered wherever I plan to crawl so I am not too worried about highway speeds. If I go with the marlin 6" whole kit that has 21" of travel what tire/ gear combo will be the best for me? Is this the best kit for the money out there?
Quote from: 1983 yota on August 29, 2007, 06:17:32 PM
personally  if youwant to rockcrawl 6 inches is too much
Marlin himself runs 37" tires  and 4 inch springs
529's  for you and a spool in the rear,  a  aussie locker up front
Shamb
I agree with Glen, typically for rockcrawling you want to keep a low center of gravity so your wheels stay on the ground as much as possible.
go with as low as a lift as possible and cut to make room for the bigger tires.
1983 yota
What is an aussie locker, 37" tires will fit 4" lift ??
Shamb
http://www.pirate4x4.com/productreviews/aussie/index.html
yes 4" lift will work with 37's  you may have to tub the firewall back depending on how much up travel you have. Along with some fender trimming.
SHSTL_82
check out the pirate 4x4 toyota FAQ will explain alot...as well as the search function on this board. lots of good stuff on the marlin board
im runing 35's (soon to be 37's) 3-4 inches of lift, welded rear, aussie up front and 5.29's...works killer.
and its driven often...damn near my DD.
check out my band if you like METAL
myspace.com/SHSTL
82 sb, 35 BFG M/T, Locked, lifted and 10 different colors.
Yoat Goat
Definetely go with the Aussie!  :cool: They are cheap (about $260 shipped to your door),  and very strong. My brother has one in his yota and he loves it.  Get on this  :phone: and call em.
T urning
O ver after
Y ears
O f
T rail
A buse
sinbob
#11
I have 35's and 5.29 gears it is a little to low on the gearing.  I haven't had any problems  with clearence with the 4 inch lift.  I should have gone with 37's and as soon aqs these wear out I will jus my :twocents:
I have a lock right frt and an ARB rear and this was my dd until i blew the head  :smack:
85 flatbed, 22RE,Downey air, redtop, dual 2.28 crawler, high steer, Marlin clutch, 5.29's, ARB rear, lockright front, Warn hubs, wrangler 4" front-skyjacker 4" r-springs w/6" shackels, flip kit, 35x12.5x15 MTR's, sliders, belly, exocage.
:support our troops :usa:
They told me I had to grow old, but they never told me I had to grow up. :cheer:
"life is not measured by the number of breaths we take, but by the moments that take our breath away" :bananasplit:
Life is not about waiting for the storm to pass, but learning to dance in the rain :dancing:
