Stupid Transmission Question
Started by blackdiamond, August 22, 2007, 06:23:54 PM
blackdiamond
I know this is a simple question, but here goes anyway.  Is the red arrow in the picture pointing to the fill hole?  I just had my transmission rebuilt and put in some Redline MT-90 and would like to verify the fluid level more than just adding the correct amount via the shifter.  The plug doesn't seem to be metric and is extremely tight (I have not managed to break it free) considering it was just removed during the rebuild.
What am I doing wrong?   :hammerhead:
that is the fill hole... it would not have had to have been removed during the rebuild because they had no reason to put fluid in it
i say even after its the right level to add a little bit more, i have heard there really isnt anything bad that can happen from it, if it is really bad, it will jsut push a litthe through the vent
blackdiamond
Quote from: jimbo74 on August 22, 2007, 06:31:10 PM
How is it possible to do a complete rebuild with bearings and syncros without draining the oil?  I know they pumped fluid in through the shifter, but it sounded like they filled it up until it ran out the fill hole.
This is a good fill point too....
notajeep
Split the case, out comes the oil... Or just use the drain plug.... Either way, why use the fill hole?
MiniSimp
I loaded mine through the fill hole till it was pouring out and capped it real quick. :twocents:
Wermz84
I like to Drive!
blackdiamond
I have a new leak that I am having trouble determining if it is the synthetic oil in the engine or the MT-90 in the transmission.  Colors are similar and the single grade MT-90 isn't "thick" and doesn't have the classic gear oil smell.  All fluids are still looking new so color doesn't help.  By smell I would guess engine oil, but location has me thinking transmission fluid.  The dipstick seems steady so I want to check the transmission level and see what it is doing and verify that it has the correct amount of fluid.  I added about 3.2-3.5 quarts through the shifter when I changed to the MT-90.
blackdiamond
Finally broke the drain plug loose using a class III receiver as a breaker bar, it was really on tight.  The good news is that there is plenty of fluid so I can't measure any loss and the engine is over filled a tiny bit so it is difficult to know if it is dropping.  I'll just have to wait knowing that everything is properly lubricated.
