f150 springs?
Started by Bs85, August 22, 2007, 02:17:14 PM
Bs85
quick question, what is the length of the f150 springs, and how good do they flex?
porkchop
Do not know length but I do know the 63" chevrolet spring is a much better flexing spring . Well that is my  :twocents: worth
85 TRUCK AUSSIE IN FRONT LINCON AROUND BACK MARLIN 4" SPRINGS UP FRONT WITH 63 CHEVYS ON BACK. REBUILT 22R WITH CRAWL CAM AND FEW OTHER THINGS NOTHING HUGE JUST WAITING TO GET PROPANE ON IT. RUNNIN 35'S M/T WITH MY LONGFIELDS 30 SPLINE SUPER AXLES. 4.7's IN T-CASE AND ON THE WAY WITH DUAL CASES. FULL HYDRO WITH TG ROCK ASSULT PUMP AND 2 X 6 AG RAM
Jakesteads
I like Toyota
Quote from: Bs85 on August 22, 2007, 02:17:14 PM
2wd f150 springs  are like 56 inches  and flex nicely
very  close in length to Marlins 4 inch rear springs
Bs85
the only thing i dont like about the chevys are they hang out the back so far cuz theyre so long and being that i bobbed my bed the shackle mount would be right under my tailgate which would put the shackle out there a couple more inches, i was just looking for a little shorter but flexy spring, im wanting to clear 35s and am going to run RUF's up front  and wanna keep it sitting level...
Bs85
i would get the marlin 4" springs but from what i hear they set your truck pretty high up in the air and i wanna keep it as low as possible.
lilbuddy
Quote from: porkchop on August 22, 2007, 07:58:34 PM
Have you used them?
They are 54 inches long and they flex great.
RIP Kyota.... you are the man
GET IT!!!
Bs85
what year 2wd f150's? and if i set them up right will 35's work u think? thanks
lilbuddy
Quote from: Bs85 on August 22, 2007, 09:02:44 PM
Late 80s to early 90s. Would they be going under a truck or a runner? If under a truck yes you can run them without a block but in a runner youd need probably a 2" block. Im running a 3" block with dual shackles in my runner and I have 37s. In my old truck I ran them with no block and my 37s fit.
GET IT!!!
porkchop
Quote from: LILBUDDY on August 22, 2007, 08:52:25 PM
Have you used them?
Have you used them?
Yes I have run the ford springs that is why I made the comment I did lil buddy. Thats why I said that was my 2 cents worth any more questions?
lilbuddy
I was just wondering because a lot of people talk :pokinit: without knowing it from first hand experiences.
GET IT!!!
Intrepidyota
I know this thread is a couple days old and I only lurk here, but I figured I would post my experience anyway.
I am running 4wd f-150 springs from a late 90's ford in my '85 4runner with a soft top. They are 3 leaf plus overload (which I cut in half) and are about 2.5" wide. They are 57" long and are 31.5" from the rear eye to the center pin, so I ran them reversed.  Using my chevy front hanger and my stock rear shackle hanger, plus a 6" eye to eye shackle (sky chevy kit) I got somewhere around 4" of lift from them (not sure exactly, had the sagged rear end to start, went to chevys, trimmed the fenders, ran these). They are thinner than my chevys, they ride better and flex as well as, if not better than the chevys, I got more lift from them, and they don't overhang the rear like the chevys did. I am very happy with them and just need to buy longer shocks as the shocks are limiting my flex now.
I ran 3 leaf chevy springs but only got about 2" of lift with sky's kit, so my ass was low compared to my rears up front. I put in an AAL and pulled the overload to gain some height and that worked well, they still flexed well, but overall, I felt they were too stiff to really match my RUF very well. I plan to bob within the next couple months so I had to do something with the springs. The ford springs worked out perfectly.
I only have a couple crappy pics of them, but here you go. 6 leaf rears up front, f-150 springs rear, trimmed the rear fenders 4" and ran 36" SX's:
springs:
Height over 34's with stock fenders:
Not that it probably does any good, but this is 4" removed from rear fenders w/ 36's:
Hope some of that helps.
Northeast Toyota Crawlers
SloCrawler
Curios if anyone knows the dimension's of a spring hanger for f150 springs. I'm fabbing a inboard hangers.
jrock
I used the ones Marlin sells and they worked great.  The springs are 2.5in and the hanger is 2 7/8in.
i used Marlins rear spring hanger
Dark Knight
sorry to be a neub on this and always late to the show.
this seems to be a good route to go with my 84 pickup, RUF and f150 springs in the rear. Will the lift height match?
SloCrawler
I'm planing on building sumthing like this.... The spring hanger part is 2 7/8" wide. Shackle pin size? Clearance around the shackle? Much appreciated..  :driving:
Quote from: Dark Knight on September 15, 2009, 01:40:01 PM
depends on how you build the ruf,  you cant just move them to the front without taking them apart and adding a couple leaves to the bottom and removing the diving board load leaf
germ85
How many spring do you add to the ruf? I got some waggy spring I think I read some where people use them to build there spring packs.
85 Yota stock on propane
flatbed
soon to have ruf, f-150s in rear hy-steer ifs box, maybe duel cases and 5.29s
