Cut and Turned Front Axle
Started by Petzl21, August 20, 2007, 06:16:29 PM
Petzl21
What companies sell cut front axle's?  I have a horrible front pinion angle, and need to get a rotated front axle.  About how much do they run?
Thanks,
Jay
Duffil
I've never seen a company sell one.  You could probably order a diamond housing to whatever degree you want, but otherwise, it's a DIY job.
Petzl21
Thats what i was afraid of.  I actually read in 4wd toyota owners mag, that proffitt's cruisers make them for the land cruiser axle's, so maybe i give them a call to see if they do mini truck axle's as well.  I just wanted to see if there was a place that already did them.
Thanks for the input though!
Jay
megolfer
cruiser outfitters sells them for cruisers also, and they are quick
AaronB
Petzl21
Quote from: Aaronb on August 21, 2007, 08:33:20 AM
get a HP third.
That is my other option.  I was just trying to price out my options.
MiniSimp
Why is your angle off?
Would rotated perches solve the problem?
What is your caster?
What is your pinion angle?
Petzl21
Quote from: MiniSimp on August 21, 2007, 10:47:35 AM
It is a harsh pinion angle due to the 5" marlin springs, with a lift shackle.  If i used just rotated perches, it would mess up my steering.  I think i am going to try and save up for a high pinion 3rd with the e-locker.
MiniSimp
You need to measure your caster first.
If your whole axle is rotated downward due to springs and shackles, then rotating your perches would bring your axle back to stock caster.
As far as your pinion angle, if you are running duals and a front double cardan driveshaft, it should not be a problem.
AaronB
Before
and after
Does yours look like the first pic?
yotadork83
i can make one for you i have done plenty of them. i charge $400 bucks for a empty housing cut and turned reinforced perches and solid steer stops. i could do it cheeper but empty housings are not cheap where i live. if you allready have one i could do it cheaper. but if you ever plan to dual case it it is not worth it. but if single cases is what you want then it is perfect. i just did one for my best friend with a 88 4runner with a allpro 6'' sas kitand the good thing about it is that it is next to impossible to pull the stock drive shaft apart. he can only do it if he drives as fast as he can in reverse and slams on his brakes on pavment.
yotas 4 life homie!
Petzl21
Quote from: yotadork83 on August 22, 2007, 07:53:50 AM
Why is this not a good option if i am running a dual case setup?  I am running dual cases and a tube front d-shafts with the DC.  Mine looks alot like the pics posted above.  If you look at my avaitor pic, you can see how low my front shaft hangs.  I can get some better pics too.
yotadork83
if you allready have dual cases and you want to rotate your axle it's ok just if you rotate it for a single case and you eventualy go to duals then your axle will be rotated to much.
yotas 4 life homie!
Petzl21
Quote from: yotadork83 on August 22, 2007, 10:43:48 AM
I will keep it in mind.  I will try and get some pics to see what people think would be best, either the high pinion, or having the axle cut and turned.  I am out in CT, so i am not sure where you are, if i decide to have you do the axle, and perches, i have to figure in shipping both ways too.
freds40
If you've got an angle grinder and welder, you can do the cut and turn yourself. It's not too difficult, just takes some time to do it right.
"between projects"
bigarms23
I know that profitts crusers sells cut and rotated axles i think the website is www.proffitscruisers.com email him and see if its cheaper if he does it. i dont know if it is cheaper than buying a hp 3rd member
Cheesemaker
Have you tried some of those degree shims that goes in between the leaf springs and the pads?
Petzl21
I have herd to never use shims up front, it would mess with the caster angles.
freds40
You can use shims as long as you don't go too far and as long as the spring bolt goes through the shim and the shim doesn't sit loose.
"between projects"
MiniSimp
Quote from: Petzl21 on August 22, 2007, 06:02:46 PM
And just what is your caster angle?????????????????????????????????????????????
Petzl21
Quote from: MiniSimp on August 22, 2007, 07:53:57 PM
I dont know exactly, is there an easy way i can measure it or do i have to go to an alignment shop to have it measured?
My current set up is the 5 inch marlin springs up front, with the 5 inch shackle.  No adjustments to the perches other than the flat plate on the drivers side.  I will try and get some pics up today or tomorrow.
freds40
If you have an angle finder, you can set it on the flat spot of the steering arm and it will tell ya where your caster is set.
"between projects"
MiniSimp
Toe In 1mm ± 2mm
Camber 1°45'± 45'
Caster 2°00' ± 1° 4Runner
2°15' ± 1° pickup
Steering Axis Inclination 9°30' ± 45'
Turning Angle: Max Angle Inside: 30°30'
Outside: 29°
Turning Angle @20° Outside Inside: 20°30'
Petzl21
Quote from: freds40 on August 23, 2007, 08:58:29 AM
So, on my marin cross over steering arms, i can place the angle finder on top of where the studs are.  I will do that tonight to check it out.
Petzl21
My Caster angle is at about a 6 degree, so if i put a 4 degree shim in there, it would be fine, b/c for a 4runner, stock is about a 2 degree +/- 1 degree, correct?
MiniSimp
Petzl21
Quote from: MiniSimp on August 27, 2007, 07:39:30 AM
Correct.
Thanks for the help everyone.  Now to go and order some shims!!!
MiniSimp
I recommend ordering them from Roger Brown http://www.4crawler.com
Make sure you weld them on.
Petzl21
Quote from: MiniSimp on August 27, 2007, 10:25:20 AM
Wow, are they really $40 for a pair of shims thru him?
MiniSimp
Quote from: Petzl21 on August 27, 2007, 06:13:24 PM
Nope
QuoteCost: US$25/pr. plus shipping and applicable sales tax:
