93 T-100 BUILD
Started by armless71, August 19, 2007, 06:18:47 PM
armless71
good points,the tranny cooler has expanded metal protecting it from sticks,also the fan relay is on a switch for the dep florida water scuba lessons,nothin else.the air tank is pretty strong,one being thicker metal,two being round and long configuration.the air tank will protect the fuel tank and tranny cooler if the driveshaft ever let go,plus its up behind the d-shaft and pretty high.i am going to build a stainless skid plate to protect the fuel cell more,maybe even somehow the t-cooler beside it.helpin my buddy think out and build his tj was hard because of less space for all the aux items.it can be done but wheelin in trees and mud and water leaves extra concerns.but thats half the fun of buildin is thinkin.thanks later
SOMEONE GIVE ME A HAND,OR TWO.
fatt_matt
awesome build, a stock t100's is sick, but your's is incredible. can't wait for more
Jeep
armless71
THANKS FOR THE PROPS......bending tubing sucks ,,,,took a whole day just to build 2 pieces.but here they are.the start of my stepside bed.heres a few pics.
DTB
armless71
i m in a qaundry about my steering cylinder placement..heres picture of my thinkin.building a mount off the axle and bolting to the steering arm.it looks like everything will clear. also got my alum diamond plate bent and sheared for the bed some pics for all to see. please any suggestion and help.thanks
skipnrocks
Gonna be cool man, I have never seen a tube step side, I cant wait to see how it comes out.  Are you going to diamond plate a skin over the step side portion?
WILLYNILLY
armless71
im probably going to use 16ga sheet metal on the outside and fenders.we fitted the alum dia today .also built the axle mount for the hydro ram.heres a pic.thanks ,later
skipnrocks
Lookin good, how are you holding the diamond plate in?  Screw?
WILLYNILLY
armless71
stainless 3/16th rivets where the side and bottom come together,then stainless 1/4 -20 buttonhead bolts on crossmembers and sides.the bulkhead will have angle iron at the top for support and a lide edge.the tailgate will have  diamond plate too.any thoughts on the steering ram.no one has said anything..thanks later
skipnrocks
I was looking at your steering setup earlier but didnt have time to ask qs.   But do you have any better pics,  how is it mounted above the axle?  It has to be mounted very stout since you mounted on the inner part of the highsteer arm there will be much more torque on it when turning.  It appears to be a full hydro ram?  I mounted mine doube shear on the axle and on the tie rod, not that its the only way to do it, but just what I did....  I would love to se some close ups and differant angles..
WILLYNILLY
armless71
its double sheer 3/4 in grd8 bolt, the plate is 5/16th, lots of gussiting.yes full hydro .im thinkin somehow of double sheer on the steering arm too.ill have better pics tommorrow.
skipnrocks
So you have a vertical 5/16 in plate off the axle tube?   Even with gussets off it I would worry a bit about it.  There is alot of stress with full hydro and lockers and big tires, another thing to think about is maybe getting a piece of halfin thich 3.5in square tube notch the bottom so it cradles the top of the axle, weld it up and put a nice little cap on it.  Again I am commenting without seeing real detailed pics of how you have it set up on the axle side but IMO it would be much stronger and more  capable of handing the shear and torsional forces of your steering setup.
WILLYNILLY
armless71
the plate runs down the top  of the axle tube,its about 10in long.then the gusseting will tie to the ends and middle wrapping down around the tube. then im gonna box it in.kinda similar to the sqaure tube idea.the ram is running parallel as possible to the tie rod.hopefully reducing twisting stress.
skipnrocks
Quote from: armless71 on December 05, 2007, 05:35:29 PM
Sounds good, looks like you have done your homework, cant wait to see how it turns out.  I did also want to ask you about skinning the rear fender wells,  I am going to be building fenders simular to that for the front of my jeep that I will skin (cause its a flattie), but I was thinking I was going to have to build a duplicate outline to the outer fender to stick in close to the body for support to the inner portion of the skin.  Are you doing something like this or did you have something else in mind?
WILLYNILLY
armless71
im gonna try to cover it with 16gauge metal like a regular stepside....try to follow the curves.hoping.then tack it to the tubing so if i dent it i can replace it.
skipnrocks
Quote from: armless71 on December 05, 2007, 06:02:27 PM
Thats cool, I am actually going to go with some 1/8 in diamond plate and run it smooth side up, I want it to be strong enough to stand on if I need to, as well as take a beating.  I was also thinking I would build a whole frame, and then build brackets to hold it on sturdy, then If I know I am going to be in tight spots I can pull them off and dont have to worry about banging them up.
WILLYNILLY
armless71
heres the axle mount for the hydralic steering ,the cardboard is the templates of the ribbing.so whatcha all think .any suggestions.
skipnrocks
Those are some pretty good pics....  Should look sweet when its all gusseted up!!
WILLYNILLY
854RUN
Truck is lookin killer. I like the gussets, they should work good
-JOSH-
ROCKO
nice build bro that truck looks bada$$ good luck with the build :thumbs:
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
ajordan1975
man your truly an amazing person  :bowdown:..... i dig the t-100. here are some pics of my buddy's. he's got a D44 up front.
armless71
thanks guys,those pics are they from houston.my buddy lives in leporte,ill probably be takin mine to go visit him this spring ,hes got lots off ridin places.should be fun..later all
ajordan1975
Quote from: armless71 on December 07, 2007, 01:21:37 PM
yeah.. they where takin a spring creek. where the we rock comp was a few months ago. let me know when you come. i will meet w/ ya for some wheeling.
armless71
that looks sweet. ill difinately let u know.probably around end feb, 1st of march.the houston live stock show is around then ,we always go.later
Doof
looking good there man. keep up the good work... hopefully one day down the road i can check this thing out with my eyes
armless71
#115
thanks,id love to ride with yall sometime.got my hydro ram built on the axle side.little paint and grinder magic and presto..heres a few pics.next plumbing it in .ordered my computer harness today.getin closer...bucket.com/albums/cc253/ARMLESS71/IMG_0694.jpg[/IMG]
skipnrocks
Hey you got your fins in....  Nice work.
WILLYNILLY
armless71
yep,gonna finish the little touches tommorrow.then work on tubing and sheet metal .fun ,im actually dieing to go riding.
skipnrocks
Quote from: armless71 on December 12, 2007, 03:38:25 PM
Im jealous,  Have fun wheelin!
WILLYNILLY
armless71
Its not done yet ,but gettin closer.heres the finished mount .im happy with it.gotta build the lines next.its hard cause i wanna work,but im at the mercy of my employee/friend.oh well,2 tears in a bucket,f--kit.
