Really need your help (stumble when throttle is applied)
Started by MiniSimp, August 07, 2007, 06:59:08 PM
Duffil
Quote from: 85xcab on August 13, 2007, 07:51:49 PM
Have you had time to check the fuel pressure yet?
flow was checked before and after the filter, but not pressure.
Have you read the thread?
MiniSimp
85xcab
Yes I have and was under the impression that you were going to check the pressure. I was just wanting to know if you had checked it yet and if so what it was.
Quote from: Duffil on August 12, 2007, 07:06:06 PM
I just got back from the NAPA.  The Mac FIPT that I have should be able to thread onto the fuel filter and tee off right there.
MINI...when is the next work day? :haha:
Quote from: MiniSimp on August 12, 2007, 08:39:10 PM
Whenever you want, I'm available from 4:30-11:00pm every day of the week, and both days this weekend. :yesnod:
Duffil
Quote from: 85xcab on August 13, 2007, 09:08:04 PM
no, I don't drive to tracy for my health...and I have to try to save for MCR6.  I'm thinkin next Sunday.
how is the bast timing? is the cam in synch with the crank? when my timing chain guides/tensioner were going out, it would skip teeth, and not go past about 3k rpms... ever.... reset the timing, and had full power back until the next time it skipped
Duffil
Quote from: jimbo74 on August 13, 2007, 09:56:40 PM
Kyle said he timed it...It is supposed to be fine.
MiniSimp
Quote from: Duffil on August 13, 2007, 09:59:35 PM
According to the timing light. However, the mark was kinda wiggling a little bit... :headscratch:
Quote from: MiniSimp on August 14, 2007, 06:10:35 AM
it will wiggle because the engine is moving... im not talking about timing it with a timing light, i am talking about internally, making sure the head and the crank are both synched with each other.... at first, i had no idea about this, i had been timing it with a light and it appeared good, it wasnt until a lot of searching online did i even know that i needed to look into the engine and make sure the crank and cam both saw each other at the same spot, thats where i found out my engine had skipped teeth on the came, it ran, jsut not very well, it wouldnt go past about 3k rpm, ever... until i relined the cam and crank, than it was back to normal until it slipped again
you'll need to pull the #1 spark plug and check for tdc, pull the valve cover to check the cams location, and also the dist cap to make sure thats all good and lined up and not 180* off
Duffil
I assumed that's what he meant.  Which is it Kyle?
MiniSimp
If teeth have skipped on the cam, I don't know about it.
When it was originally put together it was set up correctly.
Duffil
well, yank the valve cover and have a look-see.
Tice
Just pull the #1 plug and turn the engine by hand with a finger over the spark plug hole, turn till air comes out (compression stroke) and then line every thing else up.  I'm sure you already knew that!
www.wheelingarizona.com
Hottrod81
Quote from: jimbo74 on August 14, 2007, 06:51:49 AM
There is no way in hell that it will be 180 degrees off.  The engine wouldn't even run then.
MiniSimp
I'm going to put the EGR through the whole FSM test.
QuoteA Toyota EGR valve that cannot close or is stuck open makes it work like a vacuum leak and can give your vehicle a rough idle, hesitation, and even stall it out.
tom w.
Quote from: Hottrod81 on August 14, 2007, 02:31:32 PM
Are you sure? Cause my brother just rebuilt a two motors, and on both of them he had the same symptoms as mini. It ended up being that the timing was waaaaay off. Even after he checked it a couple times.
But... wasn't this thing running fine off and on?
MiniSimp
Quote from: tom w. on August 15, 2007, 07:10:25 PMBut... wasn't this thing running fine off and on?
Not really, it ran ok for about 4 minutes.
Duffil
Hottrod81
Way off is not 180 degrees off.  The firing order is completely reversed this way.
93tonkatoy
If you block the egr connection at the rear of the intake plenum, any problem with that will no longer affect the engine. I'd try it. It's only 2 bolts and something to block it with (a penny will just squeeze inside the gasket).
Quote from: MiniSimp on August 15, 2007, 11:21:50 AM
This is exactly what I was thinking the problem is. All of the vacuum controls could be operating properly, but if the valve itself cannot close,...
SAVE TELLICO post 491
MiniSimp
93tonkatoy
#140
from 1992 Haynes manual:
4 cyl - thru 88:
ign off,eng off - 33-38 psi
eng. idling
        vacuum hose detached - 33 - 38 psi
        vacuum hose attached - 27 - 31 psi
89 - on 4 cyl:
ign off, eng off - 38 - 44 psi
eng idling
        vac hose detached - 38 - 44 psi
        vac hose attached - 33 - 37 psi
*** YELLER ***
Quick responce now does anyone have the fuel pressure for an 85
:usa: :beerwhack:
except BACON
93tonkatoy
should be the same for all pre-88 efi.
fixed it.
*** YELLER ***
thanks bud it will help alot
MINI said thanks
:usa: :beerwhack:
except BACON
*** YELLER ***
he has 19 psi and good vacume  :dunno: its what he told me to post
:usa: :beerwhack:
except BACON
Willy Mammoth
here is a page from the PDF manual.
93tonkatoy
that might be a little low.
change the filter and check the screen on the pump. if you have a b/l the screen should be easier to check.
Good idea WM. I would do that first, because that will tell you if it is a bad f/p or clogged filter/screen.
Duffil
sounds like you found it. Does this mean I can go wheeling on sunday?
*** YELLER ***
Quote from: Duffil on August 17, 2007, 06:04:40 PM
he is hoping that is the problem if he gets it fixed then he said that hes gonna go to Carnigee on Sun.
Im answering for him 'cause he is busy and I just talked to him  :thumbs:
:usa: :beerwhack:
except BACON
Duffil
Quote from: oldyellercj on August 17, 2007, 06:08:24 PM
:usa: :beerwhack:
does he have another pump?
