I will get a battery today to put in my camera, I will try and cover everything from the axle to the t-case...I will be putting in a spare 3rd so while I am at it I will take pics of the extended driveshaft and also of the gears (because I know they are completely gone).
You can't shouldn't extend a shaft without replacing the whole tube and it must be true.
Check your shocks to make sure they are not worn out. The D-shaft angle could also be part of it.
In theory the shocks are good, they only have about 10k miles on them.
It's high....but I would not expect that to cause such a severe vibration. Get the CV on and lower the pinion about 3 or 4 degrees.
that ring gear is scrap iron nowand yes the odd bolt is probabbly your vibration
Not sure about your brand/style of eliminator kit, but if it's not supported directly under the leaf pad, I'd weld something in or replace it. I've had a pair of old All Pro eliminators (years ago, I think they've changed the style now) collapse and tear resulting in the pinion walking up the ring and pointing at the truck. Caught it before anything broke and had to drive up cadilac hill from rubicon springs with a chain holding the pinion down. Make sure your higher pinion angle isn't due to the perches saging.Then it was stolen..... Hope the damn things fall out again.
do u have the 2 u-joints aligned ?
What do you mean by aligned? Are you asking if they are bent? If so, they are still in good shape (remarkably).
The u-joints should be in-phase like this >>>
nope, not aligned then. The diff side is close, but the t-case side is way off from that. Hopefully I will get my diff to the right degree; and hopefully the cv will fix the problem in the front (t-case). You happen to have 360 measurements on where they should be?
Started by bthompson2902 Rigs For Sale
Started by CruzrDave Parts For Sale
Started by mr4x42u « 1 2 » Trail Reports, Events, and Gatherings
Started by rick80 Parts For Sale
Started by desrodunes1 Parts For Sale
