Author Topic: Shifters with a crawler??  (Read 1826 times)
jtaco1
  • Turtle Points: 541
  • Male Posts: 176
  • Member since Jul '07
« on: Aug 01, 2007, 08:12:34 AM »
Getting geared up to put together a MC09 crawler setup in my Tacoma.  What modifications are being done to the shifters.  From the pictures I am seeing, it looks like people are going witha short throw shifter and some other modifications.  Is this all necessary.  I have a body lift on my truck and bench seat with no center consule to get in the way.
So what I guess I am asking is can I just assemble the crawler setup, bolt it up and run the stock crawl box and Tacoma t-case shifters, bent if need be, or cut a larger hole??
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, Elocker rear axle, 37" PB Rockers and no lift
Was
99' Toyota Tacoma Crushed by Toyota
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Shifters with a crawler??
« Reply #1 on: Aug 01, 2007, 08:17:04 AM »
when installing mine  i had  to  cut a new hole  for the tcase shifter because the crawler shifter  was  in the hole the tcase was in  stock
theres  a writeup  on the  main website
jtaco1 [OP]
  • Male Posts: 176
« Reply #2 on: Aug 01, 2007, 08:22:46 AM »
Did you add a short throw shifter or a different shift base to the crawl box or t-case?  I see something like that in the writeup on the main site with the 4 runner.  Did you have to dogleg any of the shifters??
JT
Was
BruceTS
  • Member since Apr '05
« Reply #3 on: Aug 02, 2007, 03:09:10 PM »
I cut my shifters and offset them so they cleared each other. Standard throw, kept the existing shifter bases.
99 SR5 4Runner Highlander 5spd V6 4WD e-locker
Myspace
1GR-FE 4.0L V-6 & RA60F 6-speed for my project vehicle
Don't Ask when I'm gonna go SAS, I'm not... I'll build a buggy first!
jtaco1 [OP]
  • Male Posts: 176
« Reply #4 on: Aug 06, 2007, 05:10:12 AM »
Cool thanks
JT
Was
Last post Dec 10, 2003, 12:03:45 PM
by vikingsven
Last post Feb 11, 2005, 01:24:46 AM
by WHITE_TRASH
Last post Mar 10, 2006, 07:50:57 PM
by rattlecanpaint
Last post Mar 10, 2006, 09:50:48 PM
by dune_it86
Last post May 09, 2014, 12:34:38 PM
by 1985CRAWLER
