Author Topic: what size tires should i get?  (Read 3005 times)
Jakesteads
  • Turtle Points: -19
  • Male Posts: 842
  • Member since Mar '07
  • It was Nice....
« on: Jul 20, 2007, 01:40:01 PM »
picking up an 85 4runner this weekend.... this is my first yota and i have no idea how much lift this will give me i have seen some run 33's and some run 35's but i need some first hand accounts
i have some 63" chevys im gonna put in the rear and i plan on useing the rear leafs up front.....(unless someone proves this is a nono) anyone know how much lift i should get out of this or atleast what size tires..... i want to make sure this will work before i do it and just find out one is WAY bigger.....
any advice would be great. :thumbs:
I like Toyota
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: what size tires should i get?
« Reply #1 on: Jul 20, 2007, 02:03:17 PM »
About enough to fit 36-37's with a 3" fender trim :greengrin:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Jul 20, 2007, 02:07:09 PM »
ok, first things first  DONT  just  take the rear leaves  and  move them to the front,   your  ONLY supposed  to use the top two leaves,   i have  seen people  throw  RUF  :willynilly: andnot only  do they not  add  a  LONG  support leaf   but  the leave the dang  diving board  load leaf  in there  :wall:
also  IF  you do rears upfront  you MUST  change to Histeer, $399
i'm  not  crazy  about the 63  chevies  but  they work well for some
personally  i like a   2wd 80's chevy S10  or 2wd  F150 late 80's early 90's
the F150  if a extended cab  makes a very nice  spring by itself
but  even using the stock springs  and  mixing in some F150  leaves  as   long flexy  add a leaves   you can get 3-5 inches lift  and  clear 35's
Jakesteads [OP]
  • Male Posts: 842
  • It was Nice....
« Reply #3 on: Jul 20, 2007, 02:11:12 PM »
thanks for the reply i plan on first thing changing over to cross over steering ..... and was thinking of maybe just running some 4" marlins up front...... do they flex pretty well?
I like Toyota
MiniSimp
  • Male Posts: 5,120
« Reply #4 on: Jul 20, 2007, 02:23:50 PM »
I used the top 3 and the top 2 from another pack and cut them down to a 3" stagger.
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
  • Member since Dec '06
« Reply #5 on: Jul 21, 2007, 02:21:15 PM »
You know what works really well is to take a set of marlin or allpro springs and run the top two out of a set of rears in place of the top two you get from marlin or allpro. This also moves your front axle forward about two inches without screwing up you center pin location. It works great. That is what I'm running on my rock truck, I have no complaints. I took the rears off of an 82 4x truck.
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
« Reply #6 on: Jul 21, 2007, 02:25:14 PM »
By doing this and mounting my front hanger 1.5" forward, I was able to clear 37's without any tubbing.
« Reply #7 on: Jul 21, 2007, 04:53:43 PM »
thats about  the same as  the top 2 on a f150 pack,  the  f150  is like 56 inches  and Marlins are 57  :headscratch:  or  is it 57 and 56  :headscratch:
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #8 on: Jul 21, 2007, 05:03:01 PM »
marlins are 56
Quote
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #9 on: Jul 21, 2007, 05:37:11 PM »
you should run 42's.
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
« Reply #10 on: Jul 21, 2007, 05:43:46 PM »
To many broken parts, I wouldn't go any bigger than 37's unless you want to be rebuilding a diff every weekend.
« Reply #11 on: Jul 21, 2007, 05:47:37 PM »
amen brother
Last post Jan 26, 2005, 12:37:17 PM
by BLACKDOG
Last post May 25, 2007, 10:12:57 PM
by ~tc~
Last post Apr 24, 2009, 04:04:55 PM
by COToy91
Last post Mar 05, 2009, 08:56:29 PM
by THK Matt
Last post Jul 28, 2019, 12:25:54 PM
by toyodaaddict
