85 frame with 87 2 wheel cab
Started by nhyota603, July 10, 2007, 06:32:34 PM
nhyota603
   this is my yota i bought off a buddy for 300 bucks and the 2 wheel peel for 50 and there goign together to make my street rig
Quote from: nhyota603 on July 10, 2007, 06:32:34 PM
um you have to actually attach a pic to get one to post....
nhyota603
Gittinit
try photobucket, its pretty self explanatory
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
nhyota603
there soem pics of the first day
damn boy.... what i puttin on the frame? the same cab or a newer one?
nevermind i take the question back.
why a 2wd cab on a 4wd truck? any reason... or just going with what u have?
nhyota603
i got a 50 deal form a buddy so im puting the 87 standard cab on the long bed frame alomg wiht the 22r form it.im pickin up a 5 speed form a buddy and a front shift t case as well .the frame is already set up for dual cases so thats probaly whats going in it wonce i get the money.also this aint gonna be no huge trail pup cuz i gotta driveer to school next year once i get my liscence
nhyota603
cab swap is done 3 inch motor lift in and im thinkin im gonna belly pan her
nhyota603
nhyota603
got my tranny and t case in with the 3 inch motor lift and my front lifted springs and now shes siting on 38 all around.now i got to order my front axle rebuild or knuckle rebuild and find a new birfield get 4x4 yota fornt fenders and a bed driv eshafts and build a flat crossmember and i think shes ready
nhyota603
knuckle seal kit and wheel bearings will be here the 7th got long side birfeild. buildt my x member 2 inch c chanel . build my custom leaf pack. just added 2 heavy arked leafs to each pack.
nhyota603
well after riping into my front axle I fond you that my short side birfield has a blown cage so that ones junk. searching around for a mounth or 2 for a good deal around here for a whole short side and if that dont work out its um-06s from marlin
inmyownsummerami
Why did you lift the engine :confused: If it was for doing a flat belly like you mentioned, its not needed, all you need to do is push the cases up and cut out anything in the way of getting them above the bottom of the frame rails. Then weld some chain between your frame and motor mounts to keep them from ripping because of drive train torque. Here is how I did mine http://board.marlincrawler.com/index.php?topic=31672.msg363462#msg363462
By lifting the engine I assume by using taller mounts you are moving a big chunk of weight up, and not really gaining any clearance.
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
nhyota603
i got a set of blocks that move my motor up 2 and 3/4 inch up under the hood.this is because for some reason the 2 wheel drive frame or some weird thing made my lines too short so by doing this i also can use a 1 inch body lift and have my drive train out of harms way
inmyownsummerami
Quote from: nhyota603 on August 09, 2007, 09:10:13 PM
Huh.. I thought that all 2wd frames ('79-'95) were the same as the SA 4wd frames ('79-'85), as far as the section forward of the mid body mount.
nhyota603
i couldnt tel you but eather way i have 3 inches or drive train lift
nhyota603
well i driller my t case flange for the diff patterns drive shaft and its all bolted in and my shafts and knuckles and blue
norcalyota
siiiiiick riding lawnmower in the first few pics! oh nice truck too, I like the shock hoops.
JASON
nhyota603
well this fuckign sucks i went to put in my 63s and there 9 inches too long.flopp
inmyownsummerami
Are you trying to use the stock spring hangers? :headscratch:
Check out the Chevy Spring FAQ on pirate http://www.pirate4x4.com/forum/showthread.php?s=&threadid=20665
nhyota603
ther not the stock designed hangers but im pretty shure there in the same location put i put them im and now i have a wicked gangsta lean. but not to mention they front is on 38s and the back on 31s
nhyota603
yeh went to a car show today adn skored a new back window 10 bucks and a birfeild front a buddy so im repacking it and finishing up my rebuild finaly got a set of springs for the rear from a s10.she moving along
nhyota603
gont my front end dont put the 38s on and the stock bumper put in my window and crisend it with a marlin sticker
pick up soon
nhyota603
http://www.4crawler.com/4x4/ForSale/MotorMount.shtml
thats the link to the palce that sells my drivtrain lift blocks.just incase any one wants to check em out
nhyota603
the first 2 are last weekend and the other 2 are from last night
nhyota603
phh ya what do youall think abotu my jeep flairs
nhyota603
so i pushed her out of the shop today and put a battery in and she fired right up.sounds really good with just a glass pack and slight turn down.really loud.put im so exited to get her going so close
nice man... you need different fenders?
i have cut 4wd 87s.
white.
you can see how much they are cut on this thread....
http://board.marlincrawler.com/index.php?topic=36634
nhyota603
so today i went to napa and blew 60 bucks on brake lines .another 80 on a flairing tool and bender.so i did my lines tonight and the clutch line is next.the only problem is the broken off bolt in my tranny.get my easy out out and pull it out .one of my upper caliper bolts is striped out in side my knuckle .flopp. so ill see how is goes with it like that.my dad is gonna get me a rear shaft tomaro so i might be driving a nice big yota wiht my new licesnse.
