85 frame with 87 2 wheel cab
Started by nhyota603, July 10, 2007, 06:32:34 PM
oh boy cant wait to see moving and in action.... good job bud
nhyota603
thanks  so today i got my bed its steel and aluminum and it weiths about 800 lbs estimated.yep shes a beast.ill put up pics tomaro
nhyota603
a flat bed 1/4 inch wall 2 inch tubed.with diamond plate deck
Quote from: nhyota603 on October 27, 2007, 09:54:28 PM
sweeeeeeet
nhyota603
thats the new bed just after i drove her around the yard in front wheel with out any brakes
nhyota603
so iv been driving it in and out of the shop cuz it have no anti freeze and i have come to notice that i have a lot of axle wrap.does any one else have this with custom leaf packs.is there any way to fix it in the front. my rear is geting a tracktion bar so that no biggy.
Quote from: nhyota603 on November 06, 2007, 10:13:28 PM
how you getting axle wrap.. just driving it in and out of the garage.
skipnrocks
Quote from: ImahoToy85 on November 07, 2007, 12:25:12 AM
I was thinking the same thing?  I think you may have bigger problems if your getting axle wrap in the driveway...
WILLYNILLY
Quote from: skipnrocks on November 07, 2007, 06:32:44 AM
i got the same impression
nhyota603
its just leting out the clutch well pretty much dumping it
thats not axle wrap...  thats a flywheel-clutch problem.
you need some adjustment.
nhyota603
ummm idk cuz if is my pinion moving upwards and downs words. like my rear axle when i pull forward and spin the tires my springs start to s curve and thats what the front is doing. the rear is geting an adjustable tractor 3 point hitch lenghtend from the top of my frame to the crossmember over the drive shaft
skipnrocks
Your right it sounds like axlewrap, but if your wraping that easy you may want to look into differant springs,  thats sounds really bad.  There in no reason you couldnt run a traction bar to the front also, and if you intend on using the springs you have I would reccomend figuring out how to get one up there,  axle wrap can be pretty dangerous offroading especially in sticky situations...
WILLYNILLY
TRACTION BARS OF SOME SORT!!! like maybe a 2link with ortibal ends.
nhyota603
so i didnt get a drive shaft still so im still in need ill go measure the leghnth tomaro and see where it falls.ill probaly need to go to a shaft place and have one mad but i need to find a doner shaft first
nhyota603
ugh long time since iv updated but im trading a truck for a 94 t100 and 3 grand.finish my yota up and run if on easter wheeling.time to order parts . ohh boy
nhyota603
heres some pics i found from tour de rocks in nh before i got the truck
