brake up grades
Started by yota_krawler, July 05, 2007, 12:38:38 PM
yota_krawler
I have 37 inch tires on my truck and I can't stop for :pokinit:. Is there an east upgrade that doesnt cost an arm and a leg? Bigger brakes off of something that bolt up? Thanks Cody
*ROKTOY*
Would help if we new what  your driving, and what brake setup you are running now.,
yota_krawler
stock. it is an 85 all i have done is put steel braided lines on it.
*ROKTOY*
Get the FJ 60 vented rotors, v6 finned calipers and the 1" bore master cylinder. If you need more after this do a rear disc conversion.
46&2
Yeah, just check out the Marlin Crawler Brake upgrade page:
http://www.marlincrawler.com/htm/brakes.htm
They have everything you need right there.  :thumbs:
Volcom
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
yota_krawler
wow way to stress on how to spell a damn word! thanks for the correction!  :moon:
halfxspaid
I have a similar question.
If Im not going disc rears, but I am upgrading to the vented rotors and v6 calipers do I really need the 1'' bore?
85 longbed - Caged, locked, dual'd and armored
Volcom
Quote from: Yota_Krawler on July 06, 2007, 10:00:44 AM
It's a pet peeve of mine, sorry.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
*ROKTOY*
Quote from: halfxspaid on July 06, 2007, 10:48:30 AM
I would say yes as I found that the stock MC just did not provide the nice high and firm peddle I like.
halfxspaid
Additionally when doing the new FJ rotors, you must put in new wheel bearings too correct?
If i remember correctly, the races are sunk into the caliper themselves.
*ROKTOY*
NO, the rotors bolt to the wheel hub, you just have to knock out your wheel studs undo the 2 bolts remove the old rotor and install the new one.
Rocktoy2
But since you have to pull the hubs to change the rotors the only added work is changing the bearing races plus the wheel bearing kits from Marlin come with all of the gaskets you need too.  8)
*ROKTOY*
Quote from: Rocktoy2 on July 06, 2007, 03:23:09 PM
Why change your bearings if you don't need to?
46&2
I rebuilt my entire front axle when I upgraded my brakes, so I replaced practicaly everything. Depending on the condition of your wheel bearings you may not have to do it. If it has been a long time since you replaced them last, might as well do it while its all apart.  :twocents:
Rocktoy2
Quote from: fortysixandtwo on July 06, 2007, 06:05:29 PM
:thumbs:
