Making clearance in front fender wells and SAS
Started by Doable, July 03, 2007, 10:37:19 AM
Doable
Wanting to get a little room up front for bigger tires before I put the solid axle on the truck. the 1st picture is IFS with 35" MTR's.
Same tire turned all the way to the right. The 1st picture is about 3/4" turn.
The last picture is with then fender on to show how much was trimed.
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
BSLCA.com
MiniSimp
Once you have a solid axle on there you won't need all of that trimmed unless you are running larger than 37" tires.
Here is a picture with 37's no firewall trimming, just pounded down the pinchweld
Doable
To fill the hole I cut I had an old SideKick hood and used that metal to weld in and cover the opening.
Both sides got trimmed to the body mount, then primmed.
BSLCA.com
Doable
BSLCA.com
Doable
Time for my shaved 85 axle to be used again.
Along with some Marlin Crawler parts  :yesnod:
BSLCA.com
Doable
Ran into a problem with the springs that are on the axles and have to find a set of rear springs to be able to bolt everything up. The springs I have fall short. Once I get a rear pack i can mix and match them to finish it off.Weld in the shock mount and start enjoying all the hours of work and get it off the jack stands. :driving:
BSLCA.com
Doable
Quote from: MiniSimp on July 03, 2007, 10:44:28 AM
What lift springs are you running? The reason I did the mod was to keep the lift as low as I could, that way I could give up height and still run a decent  size tire.
BSLCA.com
MiniSimp
Quote from: Doable on July 03, 2007, 11:03:42 AM
Rears up front. About 1" lift.
Jordan7118
Albert, keep up the good work! Keep the progress coming! And start sportin' those sweet rims!  :eyebrow:
Doable
Ran into a sang I have the Rears up front with the Marlin hanger , the steering is Sky cross over,But coming off the steering box that arm looks to be to long .If I flex it it wants to hit the cross over bar..
The factoryarm looks to be about 7" long.Does any one make arm there for the factory Toy box but shorter??
BSLCA.com
MiniSimp
Buy this
And then move your steering box forward.
Doable
Well made some progress. Was able to finish welding on the Marlin front hanger and torched the hole in the frame for the shackle. I used 3/8" plate on the frame because the hole for the shackle was to close to the factory square hole.
I'm happy with the shackle angle
Also had time to get the (new to me stock SR5 rims all cleaned up  :yupyup: )
BSLCA.com
Jordan7118
Holy Crap! I want those rims back!  :rivers: Those things look SAAAWWWEEEETTTT!!!!
Any progress with the leaves in front? What did you decide to use?
Doable
Quote from: Jordan7118 on July 11, 2007, 05:20:34 PM
  :thumbs: Thanks again  man. Yea they did turn out pretty good.With the rest of the truck assembled  everything should look better.
Hit the junk yards and found a set of 86 rear springs and just combined them with the my original front springs they are almost flat. Tires get moved forward, shackle looks good, just will have to get a shorter pitman arm from SKY to stop the steering from hitting when I flex right now it has crazy down flex with the flat springs.
If all goes well i'll have the shock tower on, brakes hooked up and front drive shaft for the weekend.
BSLCA.com
Jordan7118
Hmmm... I'll have to add a couple leaves to the rears up front as well. How do you like the stock fronts under the rears? Flex well? Got any flex pics?
Glad I could help you, and those really do look  :bling:
Please let me know if there's any part you need, and I'll keep my eye out for it here in AR!  :thumbs:
Doable
 Where are you at on your project ?
Let me know if get the axle in B.R. I can hold it for you or if you need a hand with it.  Should have it rolling Saturday and well see how it flexes and see how the road manners are.
BSLCA.com
gtoyonrocks
I have two solid axel trucks, both of them I am running 37" tires. The majic trick is moving the front axel forward. Three inches with 4 to 5 in spings has worked well for me. No rubbing, no tubbing!!!! I did this via spring hanger and rears up front. I'm running early 80s toy rear main two on top of my fron allpro springs, the work bitchen for leafs. This moves your front axel two inches forward and the other in I get out of the hanger. This set up makes for a super soft flexy ride.
1985 toy, Hybrid 20r/22r on propane, 30splines, custom built leaf packs, welded front and rear diffs, dual ultimate crawler, full hydro, full exo, flat bed, 37' mtrs
Jordan7118
The axle actually might be shipped. The owner has a pretty good shipping rate, so I might just take advantage of that. Thanks for the offer to hold it though!
I'm still rounding up parts and spending money  :smack: I hope to start re-assembling the engine this weekend, but we'll see how that works out!
paulwhat
93 toy xcab d44 sas
BUY MY TRUCK FOR $5000 OBO
http://board.marlincrawler.com/index.php?topic=35178.0
Doable
 Today got a chance to plate the frame to put the ford shock towers on
All plated. At ride height
Fully extended
BSLCA.com
Doable
Was able to put the tabs for the brake lines on the shock towers intsead of on the frame.
Ride height
Entended
BSLCA.com
Doable
Quote from: paulwhat on July 12, 2007, 11:06:43 AM
looks like a nice rig.
Thanks I think it will all come together nicely. I had some of the stuff like axles and steering, shocks from my other 4x4 that I could reuse. That really helped on not having to dish out all the money at once.
Bleed the brakes tomorrow and take it for a short test drive  :driving:.  Ops wrong icon I have an auto  :qtip:
BSLCA.com
welder2000
I cant wait to see this thing flex, Im getting ready to do the same thing to my 83.
83 toy Clovis, CA
Jordan7118
You don't have a picture of compressed. I know the RUF will go negative like OH- (ahahaha chemistry sux...), and as such you might not have enough up-travel left in the shocks. Ya might wanna check that out.    : > )
doable  arent you in Monroe ??   how  you know Jordan  :headscratch:
:willynilly:  IM SO CONFUSED
:psss:  i dont think you have enough uptravel
measure  your  ride hieght  from axle to bumpstop,  if its  less than your shocks  you will break the shock first time you land hard on the front
Jordan7118
Quote from: 79coyotefrg on July 13, 2007, 01:57:45 PM
Albert spotted my rims that I pulled off the 85 on my pirate buildup and asked if I'd sell them. I kinda want them back, as they really cleaned up nice <tears>. But, they have a good home now, and he's doing some good work!
Albert, Glen (coyote) is right about the uptravel issue. Make sure you check it out before you wheel it and break something bad... <again, tears...>
Keep up the good work!
MiniSimp
Quit giving the guy a hard time, he has his bump-shocks set up perfect. :gap:
AaronB
Quote from: skipnrocks on November 08, 2011, 05:36:37 PM
Doable
MiniSimp ,  Man now that I have the whole suspension together you are right . With rears up front I really don't think the fender wells need to be tubbed. I just wanted the truck to stay as low as possible. Live and learn,but the pictures show that it wasn't necessary.My wife walked out side and saw the hole I cut in the floor board and  :tantrum: you just got the truck , it worked fine for the other owner did you really need to do that to it ?   :ha_ha: It was still fun to do.
Jordan, for you no more picture of the truck with the SR5 rims  :shake:. Like a kid that did not take his ADHD medicine is what it took to make them look like that.
79coyotefrg , Way lower than Monroe, I'm south of Lafayette, La. 7 hours to HotSprings.
For the front up travel I haven't flexed it yet to see what will bind. I was planning on putting regular bump stop on the u-bolt plates in addition to the bump stops on the shocks (this is how I ran them on my Samurai with good results). Thanks for the warning on on that. The last thing I want to do is tear up the work I've been doing.
BSLCA.com
Quote from: Doable on July 13, 2007, 08:40:58 PM
:yikes:  you need a boat  to go to the store ??
MAN  there used to be a  "PittGrill"  in Lafayette  that had a  all you can eat buffet,  shrimp, crawfish whatever  you wanted  :thud:
