Author Topic: used R/P pattern on Detroit  (Read 1830 times)
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
« on: Jul 02, 2007, 10:39:40 PM »
Does anyone know if a gearset from a factory open carrier can be used on a full carrier replacement locker (Detroit) and still mesh properly? I know that used gears from a stock carrier to another stock carrier is OK, but I'm not sure here...Seems I heard somewhere it wouldn't work.
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2147
  • Male Posts: 2,339
  • Member since Dec '03
  • RIP Kyle
    • Buy me a soda
Re: used R/P pattern on Detroit
« Reply #1 on: Jul 02, 2007, 11:03:17 PM »
it needs to be re set up but should work fine
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Duffil [OP]
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #2 on: Jul 02, 2007, 11:05:47 PM »
I know it has to be setup again, but I recall hearing something about a detroit had a different offset to the flange or some BS and it wouldn't work. :dunno:
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
  • Member since May '05
« Reply #3 on: Jul 02, 2007, 11:06:42 PM »
I concur with Drew. One needs to measure the backlash before removing the old gears. Then reset the same backlash when setting up with the detroit. This of course is assuming the gears were set up right from the get go.
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #4 on: Jul 02, 2007, 11:08:25 PM »
In regards to offset. You need to make sure that your Detroit is offset for the gear Ratio you are using. There are different part numbers for Detroits depending on the gear ratio.
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
« Reply #5 on: Jul 03, 2007, 12:28:28 AM »
Drew
X2.  Since you won't be removing the pinion the only thing you have to do is set bearing preload and the backlash where they were before you took it apart.
Offset would be an issue, except,  :headscratch: I believe toyota didn't have a cutoff point for ratio change for most of their gear sets. I've built toy 4.88 and 5.29's using the 4.10 case with no problems or thick gear sets. Other axle makes however seem to be more likely to require a case change in these range of ratios. I don't see why you should have any issues with going to a detroit.  :dunno: unless of course I'm wrong. Check part numbers to verify, I would.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #6 on: Jul 03, 2007, 12:38:14 AM »
i dont think toyota had the carrier split....
i know the dana 35 on my explorer had a split @ 3.73
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #7 on: Jul 03, 2007, 08:56:10 AM »
same carrier  on toys,   Duffil,  all you  need  to do is  swap the ring  from your carrier to the  detroit  then   adjust backlash,
Duffil [OP]
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #8 on: Jul 03, 2007, 03:11:38 PM »
fantastic!
Last post Feb 20, 2005, 03:56:59 PM
by UNBREAKABLE
Last post Jul 15, 2005, 01:44:15 PM
by miks85yota
Last post Jun 12, 2010, 05:23:21 AM
by Rocksurfer
Last post Jul 05, 2010, 06:06:14 PM
by WisconsinYota
Last post Aug 27, 2010, 05:12:41 PM
by crazykooter
