63" work in front and rear?
Started by porkchop, June 21, 2007, 09:25:44 AM
porkchop
I got a 85 yoatr wanting to put 63" leafs on it I jst wondering how they work on front and rear. So pleas guys tell me what it will work like and any thoughts you all have about this spring!
85 TRUCK AUSSIE IN FRONT LINCON AROUND BACK MARLIN 4" SPRINGS UP FRONT WITH 63 CHEVYS ON BACK. REBUILT 22R WITH CRAWL CAM AND FEW OTHER THINGS NOTHING HUGE JUST WAITING TO GET PROPANE ON IT. RUNNIN 35'S M/T WITH MY LONGFIELDS 30 SPLINE SUPER AXLES. 4.7's IN T-CASE AND ON THE WAY WITH DUAL CASES. FULL HYDRO WITH TG ROCK ASSULT PUMP AND 2 X 6 AG RAM
Rockcrawlintoy
they do work in the front but suck pretty bad since they are so long. there are a few guys that have run them but they had a horrible approach angle. remember they are centered so u are goin to have 31.5 inches of spring between the axle and the front hanger.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
porkchop
thanks man any suggestions on a budget of course come on guys tell what needs to be done to get it right???
Shamb
i've seen 63's front and rear on a scout years ago. worked great.. .tons of flex and was really stable. never on a toyota though..
budget?   rears up front or 44044's work well.
This is my truck about 6 years ago on 44044's
porkchop
thanks looks great what is 44044 exactly how much and were get them at?
Summit,  part number 44044
actually  a 3inch lift  waggoneer spring
Shamb
Springs!
44044 SPRINGS
44044s are Rancho Jeep Wagoneer Lift Springs.
Length: 47" (Length is eye to eye)
Center Pin split (front/rear) 22.5"/24.5"
Bushing: 2 3/4" & 3"
Lift: 5.25 - 5.5" (Lift is approximate and uses 1.5" longer than stock shackles giving 3/4" of lift)
Cost: $250 (Cost is for both sides incl. shipping/give or take)
44044's do not (by themselves) move your axle forward. They are the same length on the front half as stock toys (22.5"). While they do move the axle forward because of the lift they provide (arch in spring), when they compress to the point that they are flat, it's the same. Estimated 1/2" of actual axle relocation forward.
http://bbs.off-road.com/wwwthreads_u...ith%20dims.jpg
This is fairly old so you can find them much cheaper or even used on for sale sections of 4x4 forums.
i wonder  what kinda lift  a  set of  stock waggys  would give :think:
Shamb
Quote from: 79coyotefrg on June 25, 2007, 07:37:32 PM
3.5 to 3.75" of lift on a stock waggy spring
porkchop
thanks guys you all are a big help
Shamb
If you want further info take a look at PBB's FAQ. It has ALOT of useful info... scroll down to "springs" for different setups, specs ect.
http://www.pirate4x4.com/forum/showthread.php?t=459180
46&2
#11
I have stock waggys but I used a 2" drop box and moved it forward 1.5 inches. All together I get about 6" of lift. Not really sure how to accuratly measure my lift but if I had to guess I'd say 4-5" is a good estimate. I know its a lot bigger than my original 2" toy spring lift.
Here are some pics for you pork chop, this is my 85 4runner, 2" drop box, stock 44044s, 6" front shackle, rear 63s with dual shackles (stock chevy/6" shackle) running 35x12.50 tires.
My rear end still sits a little low so I am probably going to do about a 2" drop spring hanger in the back. I dont want to run blocks. If i was to do it over I would run 2" lifted 63s but I got a smokin' deal on a really nice set of stock 63s so I am sticking with those.
Lizard_lips
Lane from the pirates and also Troy Muse ran them front and rear.
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
porkchop
what to do?.......all look good thinking maybe crawlers on front and 63 on back that sound like it will work?
                   thanks for the ideas!
46&2
By crawlers do you mean  :turtle: springs? If so then yes, that would be an excellent combo. I would have run MC springs but my budget called for junkyard springs hence why I did the waggys and 63s. Marlin Crawler springs are worth the money though, never heard any complaints about them. They hold their ride height yet flex like crazy.
porkchop
yeah marlins on front and chevys on back sound good? :beer:
yotadork83
i did the combo of toyota rears + waggys and it was awsome i loved the spring rate very stable on road and flexy off road and had a better approch angle than just the stock waggys.
yotas 4 life homie!
46&2
Quote from: porkchop on June 30, 2007, 07:42:03 PM
Yup  :thumbs:
If you dont have your chevies already it might be a good idea to get a set of 2" lifted 63 springs. It really depends on what size marlins you get though. Are you getting 4", 5", or 6" springs? I dont know how the marlins springs sit because I dont have them myself. Hopefuly someone with marlins/63s can comment on this because I am not 100% sure how they sit compared to each other. It seems reasonable to me that 4" marlins with 63s and a 6" shackle would sit prety even.
Anyone here run Marlins up front and 63s out back?
porkchop
yeah i was going to go marlin 4 "  on front
porkchop
got my marlins for the front and chevys for back really hoping it works good on my 85 yotar with 35" any helpfull hints improvment suggestions? :turtle3:
46&2
Well if you arent sure about where to mount the rear spring hanger for the 63s check out this page. Gives you a lot of good info for doing the rear swap.
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=20665
Good luck and take some pictures for our enjoyment  :biggthumpup:
porkchop
ok guys got my chevys today they are off a 96 and they have 3 leafs and a lil short over load should i leave them like that or or modifiy them in any way?  :beer:
Gittinit
I pulled the overload leafs from my very used Chevy packs. I just couldn't see how they would benefit me , because I don't haul any loads with my toy. Even with the overloads gone and my taller than stock pershes I don't have any noticable spring wrap.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
porkchop
Yeah it is coming off . I just hoping that 63" chevies was the way to go in the rear???
46&2
Quote from: porkchop on July 19, 2007, 05:13:34 PM
I am very happy with it. I think you will be stoked with it the first time you try it on the trail. It rides great on the street too. The only problem I have is at full stuff my tires chew up my fenders. Though a sawzall is going to fix that here pretty soon.
porkchop
yeah i done broke out the  dewalt on front and flat bed on back i am going to try some pics on here of it soon thanks
