where to mount 63" chevy's
Started by auckman, June 20, 2007, 11:50:35 PM
auckman
I have an 84 ex cab, and i have a set of 63' chevies for the rear, i was wandering how far back i need to move my shackle mount and how far i need to move my front spring mount forward??
giggity
YotaJosh
From Pirate4x4:
QuoteFor the rear shackle hanger, you can either go with a double shackle set-up (very popular) or weld on a new hanger back about 4 inches from stock.
QuoteMount them 11" forward of the stock spring hanger center hole to center hole.
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=20665
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
DIRTBIKEJUNKEE
for the front spring hanger it needs to be mounted 11" forward and the shackle hanger needs to be moved 4" back or you will have to run a double shackle setup anouther thing is that the chevy springs are wider so you cant use the toyota u bolts you have to use the chevy ones and you can make your own u bolt flip kit using 1/4 inch steel, if you do decide to use the toyota flip kit you will have to grind on the springs to make them fit. good luck
Tallchevy
If your going to use the stock Toyota u-bolts, just grind the inside edge were the u-bolt contacts the spring. You don't have to take off much, just enough to get the u-bolt on. As far as the u-bolt flip kit, I went to the wrecking yard & got stock 5/8" Chevy u-bolts & plates.
87 4Runner redo
