so i got this tank it says it is made by northwest fuel systems. it is brand new and is made to bolt up where the spare tire carieir is. like this one on downey's site.
"These are sturdy 14 gauge coated steel tanks with an approximate 14 gallon capacity (varies due to evapo-emission control system). Each auxiliary tank solidly bolts to the vehicle in four mounting locations, and fits the 1979-95 4WD Pickup and 1984-89 4 Runner. When you top-off both tanks, stock and auxiliary, your gas gauge is indicating that both tanks are full. When empty, your gas gauge indicates that both tanks are empty. Tanks mount into the area immediately above the spare tire. The spare tire will mount identically (chain and crank) suspended approximately 4” lower than before. You may want to consider a suspension lift kit to buy back some of the lost ground clearance. These auxiliary tanks have their own filler neck and cap that mount at the rear of the passenger’s side rear wheel well."
i wonder if i can use it as a replacement tank. but anyone have a good sugestion on how to set up the fuel pump and a sending unit so my guage works and so i can ge t good amount of fuel to the engine???
downey site says "If using the new fuel cell as a stand alone main tank, you will not need special plumbing hardware, simply route a pickup hose from tank to fuel pump"
but it must mean an external pump im guessing. what would be a good high preformance pump???
