i need a longer shaft
Started by 90toy, June 06, 2007, 11:56:27 AM
90toy
driveshaft that is.... :shake:
my rear shaft is about 1.5-2" to short and sometimes falls out. what are you all doing to extend your rear driveshaft????
Tallchevy
Quote from: 90toy on June 06, 2007, 11:56:27 AM
:shake:
my shaft is about 1.5-2" to short and sometimes falls out. what are you all doing to extend your shaft????
That's what she said   :rofl:
j/k
Drive to you local driveline shop. They will measure it & make you a new one. $200 depending were you live.
87 4Runner redo
emsvitil
Does anyone sell and extender that has flanges on both sides?
Bolt the extender to the rear of transfer (or front if that's your problem), then bolt driveshaft to extender...
Seem's like an easier solution than redoing the driveshaft..........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Tallchevy
Quote from: emsvitil on June 06, 2007, 12:52:18 PM
It is easier but then you end up with longer bolts that bolt the driveline to the flanges. The longer the bolt the easier it is to shear off. The right way is to lengthen the driveline
87 4Runner redo
emsvitil
Quote from: Tallchevy350 on June 06, 2007, 01:04:39 PM
Flange on both ends (tubing inbetween),  normal size bolts.........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Tallchevy
I've never seen that. I thought you were talking about driveshaft spacers like some people use on Suzukis.
87 4Runner redo
emsvitil
Quote from: Tallchevy350 on June 06, 2007, 01:28:13 PM
That's the problem,  I haven't seen them either;  but it seems like such an easy idea (would make the front driveshaft lengthing easier when you get a crawler too).
Then you don't have a custom length driveshaft, and if you ever need a new one,  just goto your local junkyard for a replacement.........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Rockcrawlintoy
the local shop here charges less then 100 bucks to retube a shaft its not that big of a deal
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
