MY 1997 TACOMA SAS BUILD.. DOVED FRONT END WITH A FLAT BELLY!!
Started by lbz134, May 29, 2007, 07:15:44 PM
rednk1980
Damn Coop i didn't know you were one here. Lookin badass! like always.
twistedtoy92
mmm, i live in tricities for now, just got my drivelines done on the gray goat!!! let me know when and where thats at!?!?
your interested twistedtoy?
i will let you know asa i know.
the size and amount of trucks going, just keeps increasing.
RIGHT ON!
and sorry for jacking your thread lbz
lbz134
Quote from: rednk1980 on September 10, 2007, 09:19:23 PM
Oh ya.. Im everywhere... Going up Kanner on saturday..
DrCoop   :flamer:
THE NOW KNOWN AS "SOFT TACO" BUILD
http://board.marlincrawler.com/index.php?topic=33969.0
gtoyonrocks
Great pics man!!! Your making me want to take my truck out.
LBZ134 I dont mean to jack your thread again... but The October run i have setup... may be pushed to the beginning of november... we'll see.
Who all is still interested on here?
lbz134
Well I finally got around to doing some more tweeking on my little tacoma... I'm running 4" TG spring front and rear.. I wasnt getting a whole lot of flex out my rear end..  Using the old forklift I was only getting around 24" off the ground before I would pull the opposing rear wheel...  :confused:
So after taking a closer look at these springs I noticed that the top 4 leafs are bound together simply to hold the (in my opinion usless) axle wrap leaf..  Once I bent up the tabs and removed the extra leaf..  42"!!  What a difference!!  :beerchug:
DrCoop   :flamer:
rednk1980
lookin good Coop! We should go wheein sometime soon
lbz134
Quote from: rednk1980 on October 08, 2007, 08:42:03 PM
Definetly.. Me and yerges go up almost every weekend..
DrCoop   :flamer:
rednk1980
i think the next weekend i have off is thanksgiving. and then New Years after that
Shoyrtt
Great build. :thumbs: Do you have any pictures on how you relocated the latch to the inside of the tailgate? I am just about ready to finish my tailgate. :)
http://www.sharetrails.org/
Shoyrtt
Quote from: 3WM Yoda on October 15, 2007, 01:28:24 AM
where you get those flared bedsiade shoyrtt
They are used pre-runner bedsides I found on Racedezert.com.  :thumbs: Here is a link to how we mounted them. http://board.marlincrawler.com/index.php?topic=18832.180
88_Pathy
So what leaf did you remove? And did you bend the clamps up so that they no longer work or did you leave a slight lip at the tip so it would still work but allow the spring to separate more?
lbz134
Quote from: 88_Pathy on October 16, 2007, 02:44:01 PM
This should help ya...  You can see were the old half leaf was at due to all the rust..
DrCoop   :flamer:
88_Pathy
After you did it, did you notice any more axle wrap than before or is it the same. Also do you have dual cases?
lbz134
Quote from: 88_Pathy on October 17, 2007, 03:42:47 PM
Actually I havent had a chance to go up yet.. Hopefully this weekend.. No Dual cases.. Just stock.  I think I may goto the inchworm lefty if I can ever round up enough money.
DrCoop   :flamer:
88_Pathy
Thanks for all the help. Holy crap how did you bend those clamps up? They are super thick. I tried a cold chisel and a screw driver but could barely budge them. Did you heat them up? If so with what.
lbz134
Ya I just heated them up with a torch.. Then they bent like butter. :flamer:
DrCoop   :flamer:
lbz134
HERES A FEW PICS FROM THE LAST COUPLE WEEKENDS.. ALSO PRIOR TO BENDING MY SECOND SET OF REAR LEAF SPRINGS..
IM BUILDING A TRACTION BAR THIS WEEKEND.. HOPEFULLY THE THIRD SET WONT BEND.  BE POSTING PICS WHEN DONE..
DrCoop   :flamer:
twistedtoy92
Blazer707
thats a sick tacoma, did u ever experience a different in axle wrap after u took it up with the top leaf removed?
-Thomas
79 Hilux Bobbed *In Progress*
lbz134
Quote from: Blazer707 on November 30, 2007, 05:51:51 PM
-Thomas
unfortunatly yes.. I actually bent the living crap outa the springs first time out with the leaf removed.. (all due from axle wrap)   Im building a slip twist ladder bar this weekend, hopefully that will cure my axle wrap and save my springs...
DrCoop   :flamer:
Blazer707
so would u say take the top leaf out and at the same time build a track bar?
-Thomas
Doof
lbz134
Quote from: Blazer707 on December 01, 2007, 09:37:52 AM
-Thomas
Definetly..  I just had to learn the hard way..
DrCoop   :flamer:
