Why wouldn't you gusset the axle while it's out? I don't think the necking down on the ends is a problem, but having witnessed the effect of a semifloating rear with a bent housing (ie wheel and shaft leaving the truck at ~45 MPH), I would do what you could to strengthen the housing while it's out of the truck!
No they're not! The rear is semi-floating, held in by the pressed on bearing.Admittedly, NOBODY on TTORA or yotatech had ever heard of it happening, but it sure as hell CAN happen!
On a pressed bearing-type axle, the wheel and tire will usually remain intact , with the bearing pressed to the axleshaft holding the assembly together.
The bearing would have to fail because a shaft alone breaking will not cause the axle to come out.
if the bearing fails, the axle WILL come out.
no reason to call anyone a tool bag
I never said there wasn't a 4 bolt flanged connection which sandwiches the bearing. My point is that the bearing is not bolted to the shaft, it is merely held by friction and if you break a shaft, the bearing is not long for this world, and when the bearing fails you WILL lose the wheel/tire.
At least they're toolbags who understand how this REALLY works and aren't deluded by what they would like to think is how it works.
4 bolt flange that the pressed on bearing is bolted to that holds the axle in if you like. merely that the axle shaft is retained by the bearing that is bolted to the axle housing. That being said, a broken shaft will not cause the wheel and tire to instantly slide out, that is what bearing failure will do, which brings us back full circle to my first statement that you deemed false.
Here you mentioned twice that the bearing is bolted on.But maybe I misread what you meant. Regardless, we seem to agree that only the friction of the pressed on bearing on the axle shaft is holding the axle in the housing.Having witnessed the effect, there is a FROR full-floater kit in my future.
No, the bolts hold the brake backing plate onto the housing.The friction of the pressed on bearing holds the axle shaft in place.
Started by kyle_22r Engine
Started by donutman126 Toyota Pickup/4Runner Tech 1979-95
Started by yota_krawler Toyota Pickup/4Runner Tech 1979-95
Started by Plowking Toyota Pickup/4Runner Tech 1979-95
Started by Jess the Awesome Toyota Pickup/4Runner Tech 1979-95
