VW Jetta Q
Started by Tallchevy, May 05, 2007, 09:52:55 PM
Tallchevy
I have an 2002 VW Jetta & noticed the sun roof is leaking the other day  :smack:  I also noticed that the sun roof wasn't closing all the way to make a good seal. I know the seal is bad. My question is  how do I access the seal? Does the headliner come down? It has the side impact air bags in the pillars & I don't want to do this all day :wall:
87 4Runner redo
NT-OUTBACK
You might check over at vwvortex for an answer.
Tallchevy
Quote from: 9VLick on May 05, 2007, 11:16:00 PM
Thanks, I'll check that out  :thumbs:
87 4Runner redo
Wermz84
Yup, good vw tech there.   I'm there sometimes as well.
I like to Drive!
Shamb
yea I believe the headliner comes down, thats the way it is in my wifes 00'
YES it is a PITA, her's didn't have a leak but wasn't closing sometimes, it would stay cracked for some odd reason.
TRACKER
the problem is not in the seal  ,your sunroof have drain tubes at each corner. those tubes get clogged up with dirt and  :pokinit:.   the front drain tubes are at lower A  pillars
the rear ones run behind rear wheel wells ..you can use airgun blow them out
Pride - is what drive a man to do his very best even when no one is looking ..
Tallchevy
Quote from: TRACKER on May 06, 2007, 08:06:31 PM
Thanks  Tracker :bowdown: I'll try that first before I go any further  :thumbs:
87 4Runner redo
TRACKER
any time  ..pm me  if you have more question about your VW  .  i'm a VW tech for 6years and still work on them at local dealer ...but i love my toyota
