87 pickup SAS project
Started by 70 Cam Guy, April 29, 2007, 10:25:43 PM
70 Cam Guy
Hey everyone, I'm new to this forum but not new to message boards.  I've done my best to search here and on other sites and I'm just overwhelmed by the information.  I used to have a 1970 Camaro and ride motorcycles so off-road stuff is still somewhat new to me.  :thumbs:
'87 4x4 pickup with a 22R (no E) as a starting point.
I bought some things from people on Craigslist this weekend to get me started on the journey.  I found a new 4" sas kit, 85 axles fr & rear, and a transmission/transfer case supposedly from a carb'ed 85 (with front drive shaft).
Edits:
Updated Current list of parts:
Marlin knuckle ball gussets
Marlin 4" suspension
Marlin clutch kit (installed)
MC diff armor, bumpers, winch, smittybilt double single roll bar
still need tires and wheels, fab spare tire carrier for bed.  thinking 37s
still need front Marlin 3rd w/5.29's and e-locker, want longfield set
still need rock sliders
Updated Up in the air still:
EFI conversion... thinking about propane but I'm in California and want the truck to pass smog
Update
When I resealed the input shaft on the used transmission I found it was a G54 and it's nice and quiet on the road.  The double cardan on the 85 front driveshaft is awesome and I will just mod that d/s with long slip yoke.  The Marlin clutch and resurfaced flywheel shift nicely and the shifter bases are really smooth
Ultimately I want this to be capable yet street legal. It's my 2nd vehicle but I'd like to be able to drive it to the trails and back.  Thanks everyone!  here's a couple pics
:welcome:  to the site.  What do you mean by generic lift?  If you're not down for mixing/matching your own ruf's and f150 or chevies in the rear then I'd buy some good quality springs like marlin, alcan or allpro.  The cheaper springs are just plain poorly engineered, and the "big name" lift kits are usually jokes for toys.
70 Cam Guy
Quote from: kneedownnate on April 29, 2007, 11:05:56 PM
I was just trying to get a frame of reference on what the manufacturers recommend for basic spring lifts in the front that don't require a lot of welding (as seen in 4wheelparts).  I didn't plan on using those for my truck.  I am not sure if that '85 front driveshaft will need to be modified at all.  I figure if the 5" lifts for an 85 doesn't require front driveshaft modification, I wouldn't need it.  Then again, distance to the pinion flange might be different on my 87 I don't know :)
RHG
For a 5" lift you will need to mod the driveshaft a bit. A 7" is prolly from a "big name" comapany that doesnt plan on actually offroading the vehicle so in the kit is a billet spacer or some garbage to make the front d-shaft fit. That and they dont worry to much bout what we all strive for...FLEX!
70 Cam Guy
#5
Quote from: RHG on April 30, 2007, 12:29:28 AM
I didn't realize they just put a spacer in there, that's pretty weak!  Thanks for the info though I will definitely look closer at getting that Marlin 8" long spline shaft now.  I couldn't believe the difference in flex between the '85 shaft and the '88 driveshaft before they bound.  I feel lucky that he was too lazy to take the driveshaft off the transfer case when they gutted that truck  :gap:
Here's a shot of my friends' trucks at Eagle Lakes(Fordyce).  You can probably tell a couple of them didn't want to push it too hard (I can understand why)
70 Cam Guy
Ok it's been a while and it's been slow progress mostly due to life happening and taking up my free time.
So I've installed the FROR frame brace and encountered a hiccup with it that was easily fixed.  You can see in the pics the upper hole for the bumper.  For the install I used my little Lincoln with flux core wire.  It was set up for MIG but it just didn't have the juice to penetrate the thicker stuff to my liking.
I also installed the bumpers and front spring hanger.  The front bumper makes the tires look tiny. :hammerhead:  My friend Joey let me use the big 220 volt Lincoln at his shop in Oakland (performance options) to weld the spring hanger.  They are in the road race (short vid) and drift scene and getting their feet wet with off-road fun so I'm their guinea pig  :)
I started into the front axle prep and am starting to get more excited as I go.  Right now I'm getting my cc bill paid down so I can drop the $$ on a high pinion front 3rd and longfields.  I'm plugging away on things I can do while I save so progress isn't going too fast
on with the pics  (the gold paint is Copperweld weld through primer)
bad luck
its a start looks good so far   :best:
46&2
Looking good for sure. Those bumpers give the truck a whole new stance even with the puny little tires.
70 Cam Guy
Thanks I'm really happy with the bumpers too  :greengrin:
the front bump is made by blazen off road
Made some progress this weekend on the front axle.
I got the knuckle ball gussets ground to fit and tacked on.  My pedestal grinder got lots of use this weekend.  I'm not going to finish weld them until I go back to Joey's shop to use the big Lincoln.  The steering stops are boxed in now though that flux core wire doesn't make the prettiest welds sometimes.  I got the old 3rd member out and it appears to be in good shape except the leaky pinion seal.  It's Lincoln locked with 4.56's (I also have the complete rear axle from an '85 to match if anyone needs them)
Next up is fitting the MC diff armor.  After that I'll need the gasket for the e-locker 3rd so I can start modding the housing.  As far as the truck goes, I got the hole saw for my frame tubes and I also want to see if I can get the rear spring hanger welded up or tacked.  I also plan to tie the double single roll bar into the frame.  I'll have a plate under the bed the bar will bolt to and weld some square tube from the plate to the frame.  I figure this is better than letting the bar just sink through the bed in the event of a roll over
Progress!  I hope this is how the gussets are supposed to be oriented! :hammerhead:
ontherocks
good start on ur truck, gonna be sweet.
4.7 t-case, welded rear, 33s, sr5 buckits, sas sooner than later. http://board.marlincrawler.com/index.php?topic=74399.0
John Doe
E-locker for the front, what are you doing for the rear? You are off to a great start.
MiniSimp
Quote from: John Doe on October 15, 2007, 12:29:44 PM
Welded rear.
ontherocks
70 Cam Guy
#14
I am going to try for a selectable locker in the back too.  I've heard differing stories about detroits locking and unlocking when driving on the freeway causing control problems.  It just depends on who you talk to (like anything) but I was planning on an e-locker in the rear too.  I've also considered the ARB but with the compressor factored in, they cost a bit more... then i also wouldn't have to mod housing... ahh decisions  :ack: :gap:
Updated
nothings set in stone yet.  My big 3 purchases to go are
wheels/tires
front 3rd gears/locker/longfields
rear 3rd gears/locker
if I go ARB I can probably rebuild these 3rds I have but I don't know anyone that can set them up cheap :conf:
86bobbedtoy
hay I have a complete e-locker third for sale 550 shipped
70 Cam Guy
Quote from: 86bobbedtoy on October 16, 2007, 01:05:27 AM
seriously?  what kind of shape is it in? what gear ratio is in it? :)
ontherocks
air lines suck on arbs, go e-locker!
70 Cam Guy
I've heard about the trouble with the air lines and that's why the original plans were e-lockers :)
ontherocks
550 is a good deal for an e-locker.
70 Cam Guy
Quote from: ontherocks on October 17, 2007, 10:56:21 PM
We just talked on the phone and I just sent payment  :beerchug:
I think I'll get some 5.29's and use it in the rear.  I really want the high pinion front e locker from marlin  :yesnod:
anyone think some 37" mt/r's will fit with the 4" suspension?  Some trimming and pounding is cool but I don't want to cut out my firewall
John Doe
if your moving your front axle forward, you shouldnt have to cut the fire wall.
86bobbedtoy
Quote from: 70 Cam Guy on October 17, 2007, 11:09:06 PM
payment received
Will ship today via UPS :thumbs:
70 Cam Guy
Quote from: John Doe on October 18, 2007, 02:00:04 AM
I just installed the front spring hanger where the SAS directions recommended, which puts it slightly forward of the front frame crossmember.  Honestly I don't know if that moves things forward or not.  I'm still learning about all this stuff
70 Cam Guy
Quote from: 86bobbedtoy on October 18, 2007, 10:57:33 AM
payment received
sweet can't wait  :beerchug:
also looks like I'll have some wheels sooner than I expected.  There's some 15x10 Baja's in the sale section that I'll probably pick up tomorrow
86bobbedtoy
Them high pinion ethirds are damn nice but damn speendy but well worth it.  Your build looks great
70 Cam Guy
Thanks everyone this forum is awesome  :driving:
86bobbedtoy
Quote from: 86bobbedtoy on October 18, 2007, 09:48:30 PM
Best I've found :thumbs:   :turtle:    :thumbs: :yesnod:
X2 easiest to get around on as well.
cant wait to watch this build.
first ive watched.. thats one elockers for one.. and a high pinion front for two..
WOOT! keep up the good work.
70 Cam Guy
so I got a bucket in the mail today  :headscratch:
filled with what appears to be what used to be nice bed sheets  :screwy:
Thanks 86bobbedtoy looks great!  :cheese: :beerchug:
