ANYONE MOUNT THEIR BUMP STOP LIKE THIS?????
Started by Fearofrunner, April 26, 2007, 10:41:37 PM
Fearofrunner
Just seein what you guys think... would this work ok or is there a problem that i can't see?
Shoyrtt
I ran my front bump stops that way, but in the rear like Big Mike. The only benefit to running it on the spring I found is if you need to adjust the bump stop height, it was easier to hide the stack of 5 washers used as spacers.  :lipsrsealed::psss:
http://www.sharetrails.org/
fullthrottle
SASed 94 pu- marlin crawler 4'' springs, 5.29s aussie R lockright F 30spline longs , crawler box and 37'' SSR's
weirdtimes_7
I like that set up, FOR, you do a lot of fabing don't you, HA.. you need to take me in and teach me the way of the welder... HAHA.. but now seriously, it's time to do some mad wheelin with that thing
military_stang
:respect:
synwars
I thought thats how it is supposed to be??? ???
How are they intended to be installed? :confused:
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
DTB
Quote from: synwars on April 28, 2007, 12:58:58 PM
the tabs on the rubber stop is to be welded to the top of the ubolt plate
MR_DIY
I don't think it matters.  jed at ROCKJUNKIE4x4 runs his the way you pictured.  go for it.
I'm going yota JUST so I can buy from Marlin more.
*quote*-  goes to show that a ramp hero doesn't always have what it takes to be a trail hero as well.
DTB
Quote from: MR_DIY on April 28, 2007, 02:37:26 PM
either way is fine. i think it looks cleaner with the stop welded on the ubolt plate :twocents:
Burl
Yea thats how I did mine.
Quote from: Fearofrunner on April 26, 2007, 10:41:37 PM
guywithuglyyota
I think your hand would get tired eventually. I would mount it using a welder.
Im just being a smartass,  That location would work just fine. Look at it this way.... Im using NHL Hockey pucks for my front bumpstops.   :yupyup:
DTB
Quote from: guywithuglyyota on April 28, 2007, 05:27:06 PM
:rofl: ahahahahaha
the only advantage i could see to this is there would be more leeway in the mounting postion of the stop because there is more surface area for the stop to hit on the plate....if they are mounted correctly it wouldnt really matter though...the stop is going to hit in the same place every time
That's actually how I planned on mounting mine too :headscratch:  Seems like you could just drill and tap the bump stop drop to make future replacement easier, and if you wanted to do it better you could even weld a nut on the inside so you had more threads  :twocents:
RHG
bump stops? damn I think mine are still in the bag somewhere in the garage. Guess I'll learn when I bend a spring....doh't
