axle breathers
Started by croberts, April 15, 2007, 08:33:09 AM
RRMike
BLACKDOG
Quote from: RRMike on April 17, 2007, 06:57:56 PM
Yeah or don't waste time tapping the housing.  Brass is softer than steel and the 1/4 npt is so close it'll go in pretty easily from what I've heard.  Just screw it in.
That bellow looks like the hot ticket though!  You could just submerge the whole thing and not have to worry about running a lot of hose to keep the filter on the end dry.
exactly :thumbs:  I just threaded mine in, did it by hand until the very end :yesnod:
if by bellow you're talking about the breather cap on the pic robrub00 posted, those are crap.  That is what I replaced, I got water in my diffs all the time with those.
              -Ronald Reagan
yotaboy79
the bellow is in the link i posted and no water will not get in with them its basicly a balloon
BLACKDOG
Quote from: yotaboy79 on April 17, 2007, 10:15:28 PM
:smack: my bad.  Thought he was talkin about this stupid thing
              -Ronald Reagan
jrock
Bringing this back for the rainy season and a few questions.
How do you get a 3/8threadx1/4barb fitting to fit into an axle? Am I the only one who has trouble with this?
And why is are there so many thread standards? Metric, US (course/fine), Pipe...
robrub00
looks like people are just screwing them in.  get a tap if you want from a hardware store. or fet the metic fittings off a 22re in a junk yard. and make a hose that goes up high or into the cab.  4crawler.com has a write up i think  united staes has sae or standard metric is europe.  and there are different threads for different applications hi preassure  ie compression thread.  you have a toyota.  your in america the hardware store sells fittings for things like air compressors so you wont find a metric fitting in most hardware stores.  the 22re engines the hose from the brake booster follow it to the intake and pull the hose off bring a metric 12 wrence ( i believe might want to bring a 14 just in case)   and un screw that fitting.  go to local auto parts store.  gety some fuel line or plastic tubing or air hoes and a hose clamp!!  then get a air filter for like a lawnmower or something or a breather filter  and clap that on there. and your done!!!
bunch of stuff for sale!!!!------> http://board.marlincrawler.com/index.php?topic=31225.0
al76
I used the nissan breather it was 6 bucks and it just screwed in and used the plastic tubing like robrub said above
F**k Idacurt
jrock
I understand that the Nissan and Toyota fittings work but I have herd a lot of people staying that a 3/8 will work. I'm just wondering if there was a special way to make it fit?
robrub00
use a tap and magnet  then change your diff oil or run a magnet plug,  or  just thread it in there people are saying the brass fittings will give because they are a softer metal maybe use some teflon tape and wrench it in there!  i havent done this.  i personnly would spend the time to go to a junk yard and get the fittings in metric so i donthaveto worry about it.  your over thinking this
BLACKDOG
I pulled out the diff breather fitting, and took it into the store.  Found a female end that it threaded into, and then found the male counterpart of that female end.  Piece of cake, male fittings for both ends cost me like $6.  I got the barbed fitting, so the hose has like 2" of material to clamp onto
              -Ronald Reagan
84xcab
Bobbed 84 xtra cab, pickin up parts as I go.
If at first you do not succeed, put it in 4low and try again.
BLACKDOG
              -Ronald Reagan
OOPS
Quote from: 84xcab on November 03, 2008, 05:46:42 PM
I bought 2 of these for 1.99 ea. Think they will work?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97923
No, the fittings are the wrong size. The threads in the housing are a BPT (metric) about the same size as a 1/8th NPT. I just used 1/8 NPT brass barbs and with a little work they threaded into the wholes. The steel of the housing is harder then the brass of the fitting so it acted like a thread die. The difference in the threads between BPT and NPT is like 1 thread per inch.
jrock
Quote from: OOPS on November 03, 2008, 06:48:47 PM
What "little work" was done?
OOPS
Quote from: jkief86 on November 03, 2008, 06:52:35 PM
I filed the end with a little chamfer, pushed down on it while turning it to get it started, used a wrench to thread it into the hole going about 3/4-1 turn then backing it off to clear the threads just like you do when you use a threading die. Once I felt it was deep enough in I took it out and wrapped it with telfon tape and screwed it in. I did this many years ago and have never had any water in the diffs.
84xcab
hmm, guess I should grow some brains so I can remember to look at sizes... I guess ill cut off the fittings and still use the coil hose with new fittings.
I think brake line thread is the same pitch.  :eyebrow:
Cheesemaker
I used a 1/8" brass nipple, and just used a thread cleaner file to taper down the threads to get it to fit better.  It was all I could find in my town.  Some leftover fuel line I had, two clamps and a cheap fuel filter!  I spendt a total of less than $5.00 excluding the hose.  With hose probably $10.00 max.  I got it posted in the last page of my buildup!
