having trouble understanding duel TC's
Started by Jakesteads, March 28, 2007, 08:54:59 PM
Jakesteads
Ive been trying to read up and understand them but i still just dont get it the whole crawl box or duel case adapter things..... i mean can how do u run "2 cases" i somewhat understand the crawl box but do u need the adapter for it? just looking for some more understanding
I like Toyota
UKMyers
There are two parts to a transfer case... half of it gives you the reduction the other half gives you 2wd/4wd. When you run duals the front case is only a reduction unit and the rear case is a normal reduction/2wd-4wd. In the dual ultimate the front reduction unit has 2.28 gears and the rear case has 4.70 gears. You can run the front case in low range 2.28.1, the front case in high range and the rear in low range 4.70.1 or both cases in low range for awesome to one!!
inmyownsummerami
I think the reason people get confused about this set up is the use of the term "Dual Transfer Case". I really think the term should be abandoned and instead use "dual reduction", "compound reduction", or just plain crawl box and transfercase. This would cut down on confusion, and be more correct terminology for what is being done, and sounds better than "Dual Transfer-Case" IMO.
EDIT: BTW great explanation UKMyers.
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
Jakesteads
when running a "duel case"/ crawlbox u can't control the front and rear axles can you? you just have more range of gears to use.....am i on the right track?
I like Toyota
dov'd85
Quote from: jakesteads on March 29, 2007, 06:17:44 AM
correct you cannot control the front and rear axles. you just have a huge range of gears. 20 forward and 4 reverse gears. as far as controlling axles seperatly, you can put a twin stick in the second case and modify the shift rails and then you can be in double low range and have rear wheel drive, but you cannot achieve front digs with a toyota transfercase yet... as far as i know marlin himself is the only one that can do front digs with his toyota...
85 long bed: 30 spline long, hydro assist, hysteer, 223.1 twin sticks, 39.5 iroks, rear disk,
http://board.marlincrawler.com/index.php?topic=28696.msg344178#msg344178
toy4x4ota
u could always get a rear drive line disconnect to achieve the front digs, but thats too rich for my blood
LIFTED TRUCKS ARE GAY
Jakesteads
#6
nah im not looking to spend that kind of money..... i came from the jeep world where its atlas II and D300 twin stick....... thats why i was confused.......
i was reading another guys post about doing gears before Twin TC's....... with a dual setup do u get more range of gears? is that the reason why people say do twin first?
forgot to ask
if i wanted to do a dual TC on my 87 4runner would i want a TOP SHIFT or a FORWARD SHIFT TC to adapt to it and why also what do i have lol>?
I like Toyota
*ROKTOY*
First look under you vehicle, is the shifter attached to the transmission or the transfer case. If it is attached to the transmission then it is a forward shift, transfer case top shift. The crawl box would have to match your transmission either forward shift or top shift the rear tcase would have to be top shift. It being an 87 I would think you have a foward shift.
yota_krawler
Quote from: dov'd85 on March 29, 2007, 06:26:24 AM
Does that mean just the front tires "dig"? Why would you want that?  :dunno:
iNfErNaL
I don't know but I smell a troll...Could just be me though  :dunno:
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
dov'd85
Quote from: Yota_Krawler on March 29, 2007, 01:00:09 PM
why wouldn't you want to be able to burn the front tires and not the rear  :funny:....  it makes turning easier on tight trails sometimes you need just the front to spin and not the rear.. you can turn on a dime with front dig. who doesn't want to do front digs in a yota?? :haha: that would be the :pokinit:
dov'd85
Quote from: toy4x4ota on March 29, 2007, 08:03:54 AM
to rich and just another thing to break...
Loki
88 turd SAS with some "stuff" under it.
MY BUILD UP THREAD
yota_krawler
Jakesteads
I like Toyota
yota_krawler
what about a full floter? doen't it have hubs so you can lock it in? so if it is unlocked the rear is free? but i really see no point in wanting it front wheel drive thats just me though?
yotee
Quote from: Yota_Krawler on March 30, 2007, 08:52:12 PM
dammit, now you got me wanting to take out my flanges in the rear and put locking hubs there just to be able to turn.
iff you think about it i could drive in fwd and when 4wd is needed, just make my pass. get out and lock in.
now that is an idea.
to the original poster, if you were a jeep guy, and you know atlas,d300 ect.... then just think KLUNE-V. same thing
mike
yota_krawler
:pokinit: man it is just a little hard trying to read what someone is trying to say and not hearing thier tone etc. + getting the correct wording. Forget I ever asked K :biggthumpup: feel better?
yotee
i wasn't back talkin, that actually gave me an idea. i've been tryin to figure out how to turn my junk for a while now, you just "enlightened me" to the fact that i "could" do front digs on my truck-tell passenger to unlock rear hubs, works for me.
yota_krawler
oic, sorry  :beerchug: I thought you were looking down on what I said, I thought it would work?
dov'd85
Quote from: Yota_Krawler on March 30, 2007, 12:12:39 PM
so then how do you do it?
get an atlas,dana 300, np 203,np205 i am sure there are more... or wait till Marlin comes out with his design...
