the rust wont get any worse with clean oil in it but make sure to extend your rear end breather tube with a waterout filter.
My breather is in the tail light as well. If the H20 gets that deep you got other problems usually??
Marlin's breather kit is the best out there, all the fittings and parts in one box...$29 I think?
OK so mount it in the cab with some kind of check valve in case you roll?? That sure would suck to have the gear oil inside the cab. yuck.
if the check valve is mounted so it breathes the diff and prevents water entering, you can't also have it prevent spillage from the diff...right? they're one way, IIRC...
Really??? I thought it would be good for now... oh well, there's nothing wrong with another upgrade, hehe2military_stang
Of course it's all dependent on how hard/deep you wheel. So you might be able to get away with 2ft. But personaly i'd rather be safe then sorry. You can run out to Homedepot and get a hose connector so you can still use that 2ft and not waste it. I had to do the same, i thought 6ft would be enough for the rear, well it ended up being 10ft and there was no way i was going to waste 15$ in hose.
Started by Tsage « 1 2 » Trail Reports, Events, and Gatherings
Started by Blingn Trails & Land Use
Started by superyota Trail Reports, Events, and Gatherings
Started by deans87 Rigs For Sale
Started by Tice Transmission/Clutch
