v-6 third...
Started by yota_krawler, March 15, 2007, 10:01:49 PM
yota_krawler
I bought a 91 runner rear axle complete v-6 and also got a 89 pick up rear axle complete and was wondering if I should put the v-6 third in the 89 axle? both axle's for $150 + another 88 housing! I heard you can but not sure why. Do people do this?  :dunno:
there is nothing wrong with upgrading, but you need to make sure the gearing is the same
yota_krawler
are they stronger? would it be better to put in the front or rear. you can get the same gears for a v-6 and a 4cyl third right?
yota_krawler
what about inners? are they any stronger?
inmyownsummerami
-I don't know what you mean by inners(Axle shafts :confused:)?, but the v6 third is stronger than the 4cyl.
-You can get the same gears as the 4cyl.
-I would put it in the rear, since that is where there is the most stress.
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
yota_krawler
yeah inner axles, if not at least I have spares  :biggthumpup:
yes the rear axle shafts are the same for both rear axles you have, both are the wider version and both are 30 splined axleshafts
yota_krawler
cool good to know  :biggthumpup: . say you wanted to link your truck, can you use the coil axle to do that? I have a lot of people say I should use the coil axle to link the rear but I just want to run leaves!
inmyownsummerami
Quote from: Yota_Krawler on March 15, 2007, 11:30:00 PM
Yeah you can, but you will still be cutting off brackets and :pokinit: that you dont need, or that are in the wrong place for what you are building, so either axle would work just fine.
yota_krawler
that is what I thought and didn't want to do. I am running leaves anyway, I was just curious is to why people thought it could be done being stock. I thought you had to cut :pokinit: off but... oh do you now how much 86+ axle housing's go for?
Quote from: Yota_Krawler on March 15, 2007, 11:39:41 PMdo you now how much 86+ axle housing's go for?
they go for whatever someone is willing to pay for them
that said, they usually get a decent price as they are very desirable, they have larger brakes and are wider than the older trucks
yota_krawler
yeah, but i am selling just the housing nothing else.
inmyownsummerami
I'll give you $50 and pick it up tomorrow or this weekend. :yesnod:
