Will cj springs fit a yj?
Started by 86turboyota, March 15, 2007, 12:24:17 PM
86turboyota
My buddy got a some 4-5in lift springs from a 85 CJ for free and we are wondering if they will work on his mid 90s YJ wrangler, and if they work what else we will need to get to lift him... such as drop pitman arm and what not.. im a toyota guys so i dont realy know the jeep stuff to well....
thanks
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
iNfErNaL
Quote from: 86turboyota on March 15, 2007, 12:24:17 PM
thanks
The CJ springs are a little narrower than the YJ springs.Personally,I would skip the CJ springs and just go spring over axle with the stock YJ springs,You'll get a hell of a lot better ride and flex.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
86turboyota
so we could do a spring over using his stock flat-ass springs?   thatd just take a ubolt flip... and longer shocks and pitman drop?
iNfErNaL
Quote from: 86turboyota on March 15, 2007, 12:54:42 PM
You don't even have to get a u-bolt flip if you don't want,just weld some new spring perches on top of the axles(be sure to angle them correctly)get longer shocks,and a pitman arm.You should be able to clear 35s with very minor trimming.To me that'd be the way to go...I would also recomend doing a shackle reversal and a short shaft kit,but that's something you guys can do later down the road,you can get away with not doing that just yet.
86turboyota
right now he has a 1in body lift and extended shackles and only wants to run 33s... is that going to be too much lift if we spring over it?
86turboyota
so new spring perches, a drop pitman arm and longer shocks is all that is neccessary to do a spring over swap?
