Horse Power and Torque Q
Started by yota_krawler, February 16, 2007, 05:53:10 PM
yota_krawler
Does any one know what a 24 valve cummins motor push (HP/Torque?) I am trying to compare to what I want. Thanks. ( Definitely NOT a Chevy  :hammerhead: )
setup right  a 24 valve  can  easily  get you 300HP  and about 700 lbs of torque
yota_krawler
Quote from: 79coyotefrg on February 16, 2007, 05:55:04 PM
I know if you set them up you can get 500 hp and 1000 lbs of torque, I am wondering about stock
CTENG in KS
Depends on the year...new ones are around the 300, 600 mark.
Older they were putting out in the 500lb-ft range.
dude  300   hp  from a 24 valve  is VERY easy,  a bullydog chip  will get you that
no need  for all that bling
yota_krawler
oh I know, I was just sayin... well thanks for the info. I am looking for a 98 extended cab short bed with the 6 speed. that is like my dream tow rig,  :biggthumpup:
Tice
Quote from: Yota_Krawler on February 16, 2007, 09:05:25 PM
There is a black 98 Dodge extra cab 4x4 with a cummins at a local used car dealer in my town right now. Not sure on the trans though!!
www.wheelingarizona.com
alwayzbroken
I think the 24 valve non-HOs are around 235/460. That is a rough number from what I remember.
phi564
that will be a nice tow rig.  you can get more hp out of those trucks really easily.  Edge makes a nice module and TS is coming out with something.  let us know what you do to it.
01 Dodge 2500 Cummins dd/ tow rig
'90 toyota w/ 4.3 on propane/th350/toy duels
fj80 axles, 39" BFG krawlers, psc full hydro, 4.10's, detroit front, welderd rear
It's better to ask for forgiveness than permission
LOCKEDRUNNER
THE NEW DODGE RUNS 350 HP NOT SURE WHAT RPM AND 650 FT POUNDS OF TORQUE AT 1400 RPM.  I JUST ORDERED A 2008 FORD F-250 6.4L TWIN TURBO WITH 350 HP AT 3000 RPM AND 650 FT POUNDS OF TORQUE AT 2000 RPM.
LOCKEDRUNNER
THE DODGE RUNS 350 HP,NOT SURE AT WHAT RPM.650 FT POUNDS AT 1400 RPM. JUST ORDERED A 2008 FORD F-250 WITH A 6.4L TWIN TURBO WITH 350 HP AT 3000 RPM AND 650 FT POUNDS OF TORQUE AT 2000 RPM.A PERFECT RPM MATCH FOR MY 32' TRAVEL TRAILER
snowshoebrue
why the 98?  they didn't change the body style till 03.  plus you i think you can't get the six speed in the 98.  i have a 98 24v and my parents 02 h.o. my parents truck with a edge chip leaves my truck with a bullydog chip in the dust.  and i have cold air intake and 4" exhaust
alwayzbroken
Quote from: snowshoebrue on February 26, 2007, 04:30:23 PM
The early model year 98s have the 12 valve engine and also benefit from the new interior design and the suicide doors for the extended cab. I am pretty sure that only the NV4500 was offered in 98 and 99. I agree and see no reason to buy a 98 other than that elusive early model with the 12v.
Given the statements above that mention you want a 24 valve and a 6 speed. I do not see it feasible or worthwhile to buy a 98. I would not buy a 24 valve unless it was an HO and had a 6speed, then you would need a 2000-20002 truck, which is gonna cost you.
bnold
Here is some info for the 2nd gens:
24-VALVE TURBO DIESEL HO - 6-SPEED MANUAL TRANSMISSION
Peak Torque
505 lb-ft (from 1600 to 2700 rpm)
Advertised Power
245 hp @ 2700 rpm
Governed Speed
3200 rpm
24-VALVE TURBO DIESEL - AUTOMATIC & 5-SPEED TRANSMISSION
Peak Torque
460 lb-ft (from 1600 to 2700 rpm)
Advertised Power
235 hp @ 2700 rpm
Governed Speed
3200 rpm
24-VALVE TURBO DIESEL - GENERAL ENGINE DATA
Type
4-cycle in-line 6-cylinder
Aspiration
Turbocharged, charge air cooled
Bore & Stroke
4.02 in x 4.72 in (102 in x 120 mm)
Displacement
359 in3 (5.88 liter)
Compression Ratio
16:3:1
Firing Order
1-5-3-6-2-4
Oil Pan Capacity
2.5 US gal (9.46 liter)
24-valve 1998.5 to 2000
Auto - 215hp @ 2700rpm
420 lb-ft @ 1600rpm
Manual - 235hp @ 2700rpm
460 lb-ft @ 1600rpm
Info provided by Cattle hauler
My Baby:
Over 500hp and 1200ftlbs of torque with a little help from these:
gtoyonrocks
I know I want a Dodge, but what year??
1985 toy, Hybrid 20r/22r on propane, 30splines, custom built leaf packs, welded front and rear diffs, dual ultimate crawler, full hydro, full exo, flat bed, 37' mtrs
