79 long bed lots of goodies!!!
Started by yotadork83, February 13, 2007, 09:01:13 AM
yotadork83
here is the link to the truck that i am trying to sell i want to sell it to pay back some bills. not sure what i want for it yet i am taking offers. its an exelent work truck or start of a clean wheeler.
        engine goodies
weber 34/34 ported intake, brand new lc engineering header new 2"- 2 1/2" exuhaust with flowmaster muffler.
it has a brand new crank shaft and mid range camshaft.
electric fan, new magnacore wire set and custom loom
i will rebuild the bottom end if you want because it is burning oil or can buy as.
this thing is fast as hell with 31's on it and it has enough power to push 37's without gearing.
    truck goodies
i have a custom flat bed for it with a fitted tool box, or a custom lumber rack that fits the stock bed.
i have a reciver hitch and u-haul trailer light hook up if you want. i also have zuks custom coil helpers if needed.
front axle has been profesionaly rotated for clearance and better drive shaft angle, was rebuilt recently with the marlin maxi pad diff armor has no leaks currently.
has a custom waggy and rears pack up front with marlin 5.5 shackles front and rear.
has a five speed out of a 83, t-case has new out put seals and marlin tripple drilled flanges front and rear. drive shafts have been upgraded to newer style yokes for better angles avilibility. can drive down the free way in 4x4 with no vibs evan up to 100+mph
stuff that will be up for grabs for extras is a marlin dual plate and extra crawl box. marlin sliders if you want extra axles drive shafts and birfields.it will have a set of brand new 31 10.5 15 michilen tires or for an extra 500 i can get a new set of 35 12.5 15 bfg all teranins.
http://board.marlincrawler.com/index.php?topic=28699.0
yotas 4 life homie!
denio
denio
yotadork83
i am located in flagstaff az and right now i am just looking for a good offer not trying to make a million dollars but i am not going to sell out for way to chaep if i am going to do that i am going take every thing that is good off and make it pretty much stock and sell it like that.
yotas 4 life homie!
denio
ctdellerman
How much would you take if you didn't put the brand new tires on it (I have 5 35's)?  And just how bad is it burning oil?  Thanks, Eric
1987 4-Runner, elocker rear...gathering parts for SAS conversion
2001 Dodge 2500 4x4 QCLB Cummins Diesel 6spd HO.  Edge Juice with Attitude, Edge Jammer II injectors, AFE Stage 2, MBRP 4" exhaust, Jacobs exhaust brake, FASS fuel system, Southbend Clutch, Carli Suspension, 3" Sway-A-Ways, custom Deaver leaf packs, custom long travel airbags, 3rd gen wheels, Lukes links, DSS, Royal Utility bed
yotadork83
if you got tires i will sell it for 1300 as is. and if you want any thing else it will be more. also i have an extra motor that only has a leaky valve seal stock with 170k original miles that is running perfect at the moment. with all of the peridic matinence up to date on it if you want that long block i will swap them out for 100 bucks.
yotas 4 life homie!
