Rigs with 40s+ Gallery
Started by alwayzbroken, February 11, 2007, 08:29:48 PM
yota_krawler
yota_krawler
come on post it up!!!!  :beerchug: (everyone)
Thomas P
cody come take a pic of my truck........
'14 Camry SE
SCX10 Honcho on roids!
6.72:1
Wow, I almost forgot that was my truck!
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
yota_krawler
Thomas P
when you come over to do on board air...........
'14 Camry SE
yota_krawler
Thomas P
'14 Camry SE
swapped89
Bumpin this ole thread. I Know there are a couple guys who have recently pastthe 40" mark. Cough 89sastoy cough. :thumbs:
pumkin toy
here is a couple pics of mine. runnin 40" mtr's-   drivetrain is 7mgte with r151f, dual 23 spline ultimates, cryoed 4:88's, stock inner shafts with 27 spline long birfs, longfield hub gears, ARP hub studs.  Been wheelin it pretty hard this summer and have not had any isssues whatsoever.
97 4runner Limited
swapped89
pumkin toy
Quote from: swapped89 on July 18, 2010, 03:31:16 PM
nice save pumpkin toy :thumbs:
Yeah I would like to see this thread updated!
97 4runner Limited
swapped89
gnarrkill
40 inch mtrs
dual cases with 4.7s in the rear case
5.29s loc rite in the front and spool rear
30 splines  blah trucks being torn apart and parts are going on a 3rd gen 2wd!
79 toyota duals,caged,40 mtrs
rockcrawlinredneck
HDcruiser
Wow, thats a clean truck bro....  :drooling:
swapped89
Hey guys don't forget this thread is not just pics but also what runnng gear you have and what has broken/if anything has broken. :beerchug:
Early
Quote from: pumkin toy on July 18, 2010, 06:52:08 PM
Id like to see me in this thread  :outtahere:
Sick pumpkin Gnarr and Rock, just sick
I like watching the ones with bodies get posted  :wave:
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
89sastoyo
ill post mine up asap but photobucket won't let me log in. I'm running 42s 60 front 14bolt rear all stock 4.56s stock 14 bolt u joint and toyota at the case. Toyota u joints front and rear in the front driveline. triple cases stock 2.28s 21 spline all the way through. I rallied it up can opener not really intentionally to see if it would break but some what and it held up heres the vid..
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/IhNfOUACmoM&amp;hl=en_US&amp;fs=1?rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/IhNfOUACmoM&amp;hl=en_US&amp;fs=1?rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
I did break amy rear case front input but that was by far driver retardation. I was low low 2wd 4th and 5th gear clutch dumps trying to get up a trail that I snapped my front driveshaft in half on.
I was trying to get over two rocks about as tall as my hood with a void in the center I got to far to one side hit my driveline and it ended up in three pieces. With that being said and from seeing the vid it does pretty good. I fixed the input walked threw crushers and yeah as far as im concerned it will be fine as long as Im not doing high gear clutch dumps which I only do under certain circumstances.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
ROCK CRUSHER
on 46's
move or I will run your ass over
swapped89
bigarms23
looks like rockwells so im assuming the gears are 672s
brandon95
here are some drive way shots of my runner that isnt done yet. its on 42s w/ chevy 3/4 ton 8lug axles, 5" springs, 6"shackles
