Old news Mike!I read about this on Pirate 6 hours ago!Nice product btw!
i see in the pic above there is a mounting ear on the oem one... is there the same ear on the mc one?
What about a connector for this?
Very cool that it will work with the programmable speedo. But after I posted last night, I got to thinking and I'm not sure it will work with the computer though. I dropped a 4.3 TBI in my 83 and I think it requires a 2 pulse VSS. I'll have to do a little digging around to see if that will work. If I discover that it will, I'll definitely be ordering one. Thanks a bunch.
does this work on my 91 V6 4x4???
Yes, it is a direct replacement (using a gear drive sender, see below picture) on all 1988-2004 V6 transfercases.You need our new VSS and a sender from a gear drive t/case as shown assembled and ready to install below:BigMike
If you are using a Gear Drive T/case (1979-95) then you must use the Gear Drive 24mm VSS.If you are using a Chain Drive T/case (1988-2004+) then you must use the Chain Drive 34mm VSS.Our Marlin Crawler VSS will attach to either of these mechanical speedometer senders.
what if you want to retain your factory speedo and gauges are there any mechanic digital speed sensor combos in the works, i.e. 94 22re in an 83 sr5?
Started by Serenity now! Toyota Pickup/4Runner Tech 1979-95
Started by BigMike « 1 2 3 4 » New Announcements and Info
Started by BigMike New Announcements and Info
Started by Dmclat Transfer Case/Drive Line
Started by AWSUMDC Transfer Case/Drive Line
