Author Topic: shackle ideas for 63" chevies  (Read 6318 times)
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
Re: shackle ideas for 63" chevies
« Reply #30 on: Feb 02, 2007, 09:34:55 PM »
They are slightly wider but they will work. You will have to grind they u-bolts on the inside were the springs touch the u-bolts. I had stock u-bolts on the rear of my 83 until I did a u-bolt flip.
87 4Runner redo
Wyatt
  • Turtle Points: 22
  • Male Posts: 55
  • Member since Jan '05
  • I get stuck alot
« Reply #31 on: Feb 02, 2007, 09:37:11 PM »
Chevy springs are wider, but only by 1/4" or something.
I bought the Landcruiser already mostly built up.  All I did was get the bodywork and paint job done.  More is coming though.
-Wyatt
www.expeditionutah.com
1976 FJ55 SOA, 36"s, Hysteer, Power Steering, Aussielocked rear, Rhino Lined exterior, some other sweet stuff.
1997 FZJ80 3x Locked, OME, 33's, Nat Luna Dual Yellow Tops, Warn E 12.0, other junk
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • Member since Oct '06
  • proud parent!!!
« Reply #32 on: Feb 02, 2007, 09:39:39 PM »
so just shim it where it meets the frame? 1/8 th on each side that would be a quarter? or just spread them a little to fit or make some...
Wyatt
  • Turtle Points: 22
  • Male Posts: 55
  • I get stuck alot
« Reply #33 on: Feb 02, 2007, 09:53:52 PM »
I don't remember exactly how much wider, but either of those things will work.  As I recall, the metal sleeve in the spring eye is the widest part and you might just be able to grind it down.  If you have the springs, you can measure them and figure out smething.  If you use chevy springs, you need to move your shackle hanger back anyway, so you might as well fab a new one or modify the old one to one that is the same width.
-Wyatt
Tallchevy
  • Male Posts: 3,562
« Reply #34 on: Feb 02, 2007, 09:56:30 PM »
Thats a sweet rig Wyatt. Toyotajoe35, post a pic of your current rear set up.
87 4Runner redo
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
« Reply #35 on: Feb 02, 2007, 09:58:29 PM »
there's an all stock FJ55 around the corner from me.
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
« Reply #36 on: Feb 02, 2007, 10:04:11 PM »
Cool thanks for the info
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #37 on: Feb 02, 2007, 10:27:30 PM »
i don't see why you are saying that it doesn't give you any off-road advantage.  a truck with the same size lift, tires, and width, one witha flexy suspension and one with a stiffer suspension.  the flexy one will perform much better off-road and would be less likely to roll.  by having more flex you are keeping all four tires on the ground which obviously will give you more traction then only 3 tires.  i don't see how the double shackle made your truck roll.  what did it do?  push your truck over?  even if you had a single shackle i would bet you would have rolled too.  i have rolled my truck many times but it has never been the double shackles fault.  the double shackle isn't like a buggy leaf which can push the shackle down.
Last post Oct 10, 2005, 09:26:21 PM
by fabtoys
Last post Dec 17, 2007, 12:24:44 PM
by twistedtoy92
Last post Nov 02, 2009, 10:13:54 PM
by Thomas P
Last post Oct 27, 2011, 10:50:07 AM
by Aaronm
Last post May 18, 2012, 11:12:16 AM
by jeremiah
