Diamond axle...comes with?/
Started by creeperjeep, January 23, 2007, 09:32:07 PM
creeperjeep
On diamonds site it lists a D44 outered housing
I assume for 900 but what does that come with?
Has anyone had any dealings with them
forgive my yotanebness
Shamb
Team Ramrod's got one on the way, maybe he'll chim in.
Should say on the website specifically what it comes with though...
RokCrawlinToy
I got a set coming soon. Here is the info. from their website. I would just give Brian a call if you're serious.
Pricing:
Toyota Front Housing:
Fabricated center, providing 3/4"+ extra ground clearance
1" thick solid steering stops
3rd Member mounting hardware
Breather
Magnetic fill plug and gasket
$900
9" Center, Dana 60 Outer Steer Housing:
Dedenbear C's installed
Spicer axle shaft seals
ARP and grade 8 3rd member mounting hardware
Breather
$1250
Options
Front center sections:
Ford 9" - 31 or 35 spline
Toyota 4cyl/V6, Hi-pinion/low pinion, standard/Electric locker
T100/Tundra/"8.4" - 30 or 35 spline
Outers:
Toyota (birfield based) - 6 lug
Dana 44 balljoint
- 5, 6, or 8 lug
Dana 60 King Pin - 5, 6, or 8 lug
