fordh8r's 84 Xtra-bad Daily Driver
Started by fordh8r, January 15, 2007, 06:23:33 PM
fordh8r
back to the project...
    Frame brackets in place after some  :flamer:. you can see the right side is clearanced for the parking brake cable.  :yesnod:
fordh8r
#31
I added a stiffener (1/8 x 1 channel) to the X-member for some rigidity.  It was a little flexy at first but not any more.  :cheese:  :gap:
fordh8r
1)  The final fit... :cheer: :hyper:
2)  plenty of room for the stiffener brace to the case... :gap:  Hey that rhymed... :hahaha:
3)  and ample clearance for the front shaft... :gap:
fordh8r
After some slight adjusting of the X-member by opening up the area where the rear mount is... :flamer:
Had to do this so the big bolt thingy in the middle of the mount wouldn't hit the plate and cause any Mystery noises.   :gap:
now it's time for some paint and some  :bling:.... :turtle: stickers.... :yupyup:
twistedtoy92
Wermz84
Quote from: fordh8r on October 14, 2007, 11:12:24 PM
I have read your thread...Good stuff too!   :bowdown:  Sorry, to see you had  such a time with your tranny. At least it's fixed now. I like the Durabak you put on your floor. I've never used that stuff before. how was it to work with? And how $$$?  Looking good, nonetheless... :biggthumpup:
Roger that!  :usa:   Also, what's new with your ride? Still would like to see more... :cheese:
Thanks alot, I appreciate it.   :beerchug:  the Tranny is running better than ever, Marlin and Angelo went over and above.  :yesnod:
The Durabak is awsome.  Around $95 with shipping to get it to me, been over a year and it is holding up great.   Easy to work with  :thumbs:
Nothing new as of right now, but there will be more.   :beerchug:
This is exactly what I was asking about.  Looking good.  :biggthumpup:
And I like the cross brace inside.
Let me know when you take it to Hollister!!   Make sure tallchevy comes to.  :yupyup:
I like to Drive!
fordh8r
Quote from: Wermz84 on October 18, 2007, 10:40:24 PM
Cool and thanks for the info I'll have to check it out sometime!  :biggthumpup:
Thanks again on the brace I am pleased with it's outcome so far... :yupyup:
Yeah, as far as Hollister goes.....that's like women going to the bathhroom in public places, we never go alone!   :disturbed:  :rofl:
In fact, He's on his way now and we are off to Glamis!  :hyper:  Be back late Mon. night!  :yupyup:
Hey Peps, you comin?!  :beerchug:
Wermz84
I like to Drive!
fordh8r
#38
 Finally, some more pics and work done... :gap:
    1)  a little paint and some  :bling: decals... :yupyup: Hopefully this will be the last time you'll be able to see both
         decals at once... :gap:
    2)  Also boys and girls remember to clear coat your decals for longer lasting colors and to prevent short term peeling
         from washing them... :thumbs:  :yesnod:
fordh8r
Here it is!  All bolted up and ready for action!  :thumbs:  Drive line getting done as we post... :yupyup:
fordh8r
Well, got the driveline in today and took it for a little spin.  :hyper:   It all feels good so far, nice and smooth.  :biggthumpup:   I can tell the drivetrain is firmer with the added motor mount.  :gap:   I tried the dual low range... :yupyup:   I like!  :drooling:
Now for phase 2!  the front end!  :flamer:  :thud:
fordh8r
after my test drive I turned my truck around to start tearing into the front end.  :gap:
1)  just for comparison....my old lift springs and the stock rears.
2)  the static differnce in center bolt location.
3)  after stripping all the old stuff off... :gap:
fordh8r
1)  My new shackle angle... :thumbs:
2)  The new spring pack sits very similar to one I replaced...after mixing springs from my old lift springs and the stock
     rears  I gained only a 1/2 inch of lift which I expect to settle some... :yesnod:
3)  The axle is definitely moved forward.  :thumbs:
The reason I did this modification wasn't for more flex (well, some  :gap:) or even a nicer ride (which couldn't hurt  :greengrin:), all of which are good benifits to RUF's, but mostly so I could fit bigger tires without having to go higher.    :yupyup:
fordh8r
the new stance is what I was looking for and also I hadn't mentioned the Diff gaurds that I welded on about 3 months ago... :gap:
fordh8r
Now for the high tech stuff... :disturbed:
Since I was so busy with all this cool stuff I nearly forgot about  a silly detail like my windshield leak  :smack: which wets my feet when I drive... :tantrum:   So I found my trusty color coordinated weather sealing strip... :gap:
fordh8r
Ok, so today I took a trip to the North Pole to visit SC  :santa:......Actually, no, I went to Fresno to visit MC :turtle: to pick up some more parts for my project.  So me and my dog jumped in the car and 2 1/2 hours later found ourselves here.
fordh8r
I got home with the goodies and here's what I got.... :hyper:
  1)  first, I got the front U-bolt flip kit
  2) then I also picked up a knuckle ball gusset kit and some much needed boots and an additional  :turtle3: knob to
      complete my shifter ensemble... :gap:
Hopefully I can get out there soon to start this stuff but I've been  :sick: with pneumonia and haven't had any parts anyway... :down:.  But now that's changed and we got a long weekend ahead... :woohoo:.  If it all works out ok Ill have more pics in a few days. Stay tuned!  :biggthumpup:
fordh8r
Quote from: Wermz84 on November 19, 2007, 06:27:01 PM
glad your feeling better.
Thanks!  :beerchug:  I'm looking forward to getting back to business with my junk... :yupyup:
fordh8r
Quote from: tom w. on November 20, 2007, 09:50:37 AM
What you do in the privacy of your own home is your business...
I'm not shy... :yupyup:  I'll even post pics... :snapshot: :bumpinbutts:  :horseride: :bud: :gap: :disturbed: :rofl: :rofl:
I did start some gear work today (my 4.88's), however. No pics of that  :down: since I figured most everyone here knows what that looks like by now, so nothing special to show there but it is getting done... :biggthumpup:
Wermz84
I like to Drive!
fordh8r
Got to do a little more today... :hyper:
Lotsa cuttin and grindin today just to clean up the unused stuff from the axle housing.  :gap:
prepped and ready for welding on the knuckle ball kit from Marlin... :biggthumpup:
Tomorrow the work will continue... more pics to come... :snapshot: :woohoo:
fordh8r
An over due happening with all the work so far... :smack:  :gap:  :disturbed:
fordh8r
got some more work done this weekend. Got the knuckle bal kit welded on and the steering stops boxed in... :hyper:  Oh so close, yet so far... :biggthumpup:
fordh8r
Knuckles and hubs are all assembled and starting to look like a useable component again... :yupyup:   Got the start of my X-over steering just need my IFS box mount now... :eye: :eye:.  Once the IFS box is in then it will be driveable....somewhat (read next posts)
fordh8r
First I found this... :o   How could this happen with only 31's... :gap:  Good thing I had a spare and I used that to get this thing together... :cheese:
fordh8r
Optical dillusion?   I wish... :down:
fordh8r
  Hard to see in these pics but it's there. There is a hint of a crack or it's just the surface crud that cracked when the spring perch crushed while torquing the U-bolts... :headscratch:  I thought it was kinda strange how that U-bolt seemed to keep going before it finally torqued up... :hammerhead:
   Guess I'll have to make a new one  :headshake:.  I'm thinking of making one tall enough to eliminate the spacer plate on the spring  :yesnod:.  I'm gonna wait till everything else is done before I come back to this problem.  Got plenty of other unfinished business at this point so I'll just keep moving to get bigger stuff done first  :gap:.
fordh8r
Quote from: tom w. on November 29, 2007, 09:38:40 AM
What leaves are those you got there?
Top three leaves are from rears... :biggthumpup:   The upper of the two lower leaves are from a skyjacker lift which I had on here previously... :gap:   and the bottom leaf was a chevy 2" AAL which was chopped and shaped for added comfort instead of the full leaf... :cheese:.
   I haven't driven on these yet so I don't know much about the ride or flex but I'm hoping I won't have to do much tuning...we'll see... :eyebrow:
fordh8r
Quote from: tom w. on November 29, 2007, 01:30:07 PM
I bet you won't have to do much to them...
Thanks!  :thumbs:  I hope I won't... :cheese:   I can stand it to be a little stiff just not too rough for daily driving. Besides, it's probably gonna be better than it was before with the complete lift spring.  :greengrin:
fordh8r
#59
Ok, so I got my 35's on today...  :wiggle:
