WHO MAKES THE BEST CHROMOLY FRONT INNER/OUTER SHAFTS?
Started by tryn2Crawl, January 13, 2007, 04:08:39 PM
tryn2Crawl
In the market for some inner shafts for my front toy.  axle.  Who makes the best on the market and what about the warranty they each carry?  Would like to hear from folks who actually runs them not what they heard only. If i wanted that I would search on YAHOO!!!!!!!!!
So please. Only from those who has first hand experience running these.Thanks.
DTB
Fearofrunner
Quotelongfields....is there anything else?  http://www.longfieldsuperaxles.com/
nothing worth wasting money on...longfields hands down.
yotaboy79
get the longs but also get his hub gears when you do that cuz the next week link is the hub gear and when it breaks it will normaly strip out the splines on the birf and bobby wont warenty it if that happens because its not the birf that broke, a little extra insurance thats well worth it
DTB
KYOTA
 like yotaboy said Bobby will only warranty a birf with stripped splines if you're running his cromo hub gears, next weakest link after that is the hub studs. I'm running Long's 30's and inners with the cromo hub gears and FROR's cromo ARP hubs studs
topar
Fearofrunner
QuoteInsert Quote
Quote
Just answering your question, but it was my bad cause i thought allpro still had there profields  and heard that they didn't hold up to longfieds when longfield tested them.  sorry about that. :smack:
KYOTA
 :talkingn: the profields were weaker than a stock birf when tested on Longs machine
DTB
kyota do u have that comparison chart of breaking strengths? I couldnt find mine
KYOTA
from the "Bobby Longs Axle Breaking Machine Results" thread
http://www.pirate4x4.com/forum/showthread.php?t=467075
PRODUCT / ................................................. FT.LB. TORQUE/.... % TWIST
Yukon 4340 Dana 60 35 spline short side axle.........12,000 ..................130
Stock Dana 60 35 spline short side axle .................6,500 ....................35
Yukon 4340 Dana 44 30 spline short side axle ..........5,800 ...................35
Stock dana 44 30 spline........................................5,00 0.....................35
Yukon 4340 Birfield Eliminator kit (ear failure)............5,500......................50
Longfield 4340 30 spline (shaft failure)......................8,500............... ......175
Longfield 4340 27 spline........................................6,50 0.....................75
Stock Toyota Birfield.......................................... ..4,200 .....................45
Stock Toyota Inner Axle.......................................5,000 .....................45
All Pro "Profield"........................................ .......... 3,500 ....................30
Stock toyota Transfer Case Output Shaft.................2,500 ....................65
Longfield treated Transfer case output shaft.............2,500.....................20
Longfield 4340 Transfer Case Output Shaft...............4,000......................25
All Pro Transfer Case Output Shaft..........................2,500 ......................60
Marlin "treated" Transfer Case Output Shaft..............2,500 ......................10
Stock Toyota Hub............................................... .5,800/
Longfield Treated Toy Hub ....................................6,800/
Stock Toyota Flange............................................ .6,000/
Longfield 4340 Flange............................................ Didn't test
