Author Topic: installing auto meter oil press gauge... what  (Read 2255 times)
SQUIRREL MONSTER
  • Turtle Points: 151
  • Male Posts: 657
  • Member since Jul '05
  • squirrel powered by hampsterous oxide!
« on: Jan 12, 2007, 01:09:11 PM »
ok, so i am installing a new auto meter elec. oil pressure gauge. i have a non SR5 gauge cluster (hence the auto meter gauge installation) so i likely have the sending unit for the dummy light. my question being, if i get the toyota sending unit originally made for the pressure gauge will it read wrong or off on the auto meter gauge or should i use the sending unit that comes with the gauge and find the standard to metric adaptor?
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: installing auto meter oil press gauge... what
« Reply #1 on: Jan 12, 2007, 01:43:44 PM »
I"d use the SU that Auto-Meter supplied and just re cut the threads on the fitting in the kit. I have the Auto-Meter mechanical OP gauge and the the fitting for the block was so damn close and it being brass I ran the proper die over it and threaded right in. I dont remember of the top of my head what the threads are but IIRC its BSP not metric. I can go look here in a few if you want.
« Last Edit: Jan 12, 2007, 03:56:49 PM by KYOTA »
KYOTA
  • Wreckin Ball '09
« Reply #2 on: Jan 12, 2007, 03:59:26 PM »
OK I found the die I used for mine, its 1/8" BSP (British Standard Pipe)
madhunt
  • Turtle Points: 52
  • Male Posts: 490
  • Member since Apr '06
« Reply #3 on: Jan 12, 2007, 04:02:17 PM »
go to any napa or carquest and buy the adpaters for the gauges
HIGH AND TIGHT OFFROAD
SQUIRREL MONSTER [OP]
  • Male Posts: 657
« Reply #4 on: Jan 12, 2007, 07:24:12 PM »
hey thanks guys! this makes it a bunch easier. ill look and see if my buddy has that die... if he dont ill hit up napa. thanks once again.
dcg9381
  • Member since May '05
« Reply #5 on: Jan 18, 2007, 12:40:35 PM »
Behind the passenger side engine mount, there's another oil port.  If you can get the right BSP to NPT adapter and 45 degrees, you can extend this port a few inches with a 1/8 npt extension.. Just plug the autometer sender in and have both.
Toyota and GM sensors are not compatible.. At least not in most case - intake air temp, coolant temp, blah blah
  • Male Posts: 657
« Reply #6 on: Jan 18, 2007, 08:06:41 PM »
hmm. i didnt know that, ill have to take a look at this. i didnt get a chance to do it last weekend but ill have time this weekend so ill check it out. i only seen the regular sensor near the front but the starter and other stuff may have obstructed my view of the other plug. thanks.
dcg9381
« Reply #7 on: Jan 21, 2007, 07:47:34 AM »
  • Male Posts: 657
« Reply #8 on: Jan 27, 2007, 01:19:19 AM »
dcg- do you remember the size adapter fitting you need to go from the auto meter sending unit to the stock toyota sending unit port?
dcg9381
« Reply #9 on: Feb 05, 2007, 09:29:20 PM »
1/8 BSP to 1/8 NTP- I think summit an jegs both sell the adapter.. Comes with some gauge kits.
Last post Oct 16, 2004, 02:26:42 PM
by 94toytruck
Last post Apr 19, 2006, 09:09:24 PM
by Skinny_Pedal
Last post Feb 14, 2007, 12:18:35 PM
by sbc1875
Last post Jun 11, 2008, 08:15:23 AM
by afcrawler
Last post Jan 12, 2024, 11:32:08 AM
by James874runner
