Author Topic: pinion bearing  (Read 1078 times)
4.3s10
  • Turtle Points: -116
  • Male Posts: 128
  • Member since Aug '05
  • There's no replacement for displacement
pinion bearing
« on: Nov 30, 2006, 05:05:18 PM »
I am setting up 85xtracabs third member he just bought it has 5.29s gears  and was out of 91 4runner  v6. but when i looked at it the gear pattern was a little off so i decided that i would set it up better than it is now. i need to change the pinion depth so i pressed the pinion gears off and am going to hone them out so the slip on and off the pinion easy so i can find the correct shim then replace those bearings with new ones  What i was wondering is if stock gears use a slightly different than aftermarket gears  like the I.D. of the bearing  was off . It has koyo bearings in it today at work i tried crossing those koyo bearing numbers and they didn't work. so i was wondering if you knew any other numbers for both of the pinion bearings because i don't need a whole gear set up kit just both pinion bearings. i think the gears are precision gears just wondering where i could find just a set of those with out the install kit
i was also wondering what a good starting point would be for the thickness of the shim should be i pulled out 2 that combined were .067 which seems like a lot i was thinking more in th .030 range.
1990 s10
4.3 bored out .030
Dynomax cat back
tbi spacer
Flowmaster delta 50
Holley 670
Accel coil
2 add-a-leafs
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: pinion bearing
« Reply #1 on: Nov 30, 2006, 05:55:01 PM »
pm ZUK
Matty
  • Turtle Points: -18
  • Male Posts: 875
  • Member since Jul '05
Re: pinion bearing
« Reply #2 on: Nov 30, 2006, 06:51:08 PM »
hurry it up i need to go  :driving:
justt kidding nice work  :drool:
Last post Mar 16, 2004, 06:30:00 PM
by bamayote
Last post Sep 07, 2008, 11:47:13 AM
by bloodsweatbeers
Last post Nov 02, 2004, 03:08:28 PM
by Mike D
Last post Apr 05, 2006, 12:51:04 PM
by CTENG in KS
Last post Sep 23, 2007, 06:34:24 PM
by notajeep
