need info on 4x4ing in the snow?
Started by 89 yota, November 24, 2006, 04:06:57 PM
89 yota
got stuck in the snow today. went up the hill and came back down sliding, and would like to know what to do in that situation?
blackdiamond
Quote from: 89 yota on November 24, 2006, 04:06:57 PM
I'm not a snow wheeling expert, but I can provide some advise.
Before starting your trip in the snow make sure you air down your tires.  The air pressure in your tires probably matters more on snow than any other surface.  The lower you go the better as long as you don't lose the bead.
It sounds like you tried to climb a hill, failed to reach the top, and came sliding back down the hill?  Once traction is lost there isn't much you can do but try and avoid running into things.  This is the downside to snow and why I don't like wheeling in the mud...I prefer to be in control and sometimes that simply doesn't happen in snow.  If you keep your wheels turning/spinning you can help avoid having the tires grab and rolling you over if you get sideways on the hill.  Just try to keep it straight and avoid running into stuff.
DTB
when in doubt, throttle it out lol :driving:
what kind of tires u running? that makes a big diff.....
u did lock hubs in 4wd right? :eek:
notajeep
blackdiamond
Momentum is key, wheel spin often only cause the tires to dig holes.  Staying on top of snow is a balanced "art" that can only be learned from experience.  I've got a ways to go.
89 yota
well i have 33 12.5 BFG's A/T. yes i was locked in 4 wheel drive
DTB
Quote from: 89 yota on November 25, 2006, 01:28:37 PM
Those tires should do okay in the snow. So then yea, air down your tires to like under 10 psi (what size wheels u running?) and hit it with speed. Installing a locker or two wouldnt hurt either :yupyup:
YotaJohnBoy4x4
mckenzie... too much gas will hurt you because youll break the tires loose then lose all your traction so depending on how steep it was... get a bit of a run at it and hit about 4low 2nd gear so you have good momentum and just dont let out of it... as far as sliding down backwards... jam it in reverse as best and quickly as you can and use the gas to steer it back and forth... ill show you sometime... and get some goodyear mt/rs
"lil truck rolling on 37s"
alwayzbroken
The best advise for wheeling in the snow is bring a jacket and figure it out as you go. Nobody can tell you how to drive.
DTB
Quote from: alwayzbroken on November 25, 2006, 04:24:28 PM
GOOD POINT! :clap:
rednk1980
1st try airing down
2nd try johns idea
3rd put in a locker or dual cases and locker
or all of the above!
:twocents:
89 yota
thanks you guy's for the info. Maybe I will make it to the top the next time.  :crossed:
DTB
Quote from: 89 yota on November 27, 2006, 08:36:48 PM
take pictures :worthless:
89 yota
My friend has pics on his phone I will get them when he comes back over :snapshot:
milla85
What is a safe tire PSI i can air down to if i have 32 tsl and 15x8 rims.
rednk1980
i run my 33 12.50/15 between 5-7 and have only blown one beed (because i was being stupid)
cruzila
rude86
member of team marlin crawler
Destruct O
I am not a snow driving except I am just sharing my experience in being stuck in it and not having the right tools to make getting un-stuck allot easier. If you are coming right off the highway or traveled a good distance to go play in the snow try really really hard and wait for your tires to cool down before you go. Get and use a set of tire chains, air down but not to much when your using chains, add a decent amount of weight in the back of your rig. "Bring a shovel" tow strap or tow chain, some wood like a couple of 2x4s, cinders, sand, kitty litter or anything that won't dissolve when it gets wet and is not bad for the environment. You might want to pump some fresh grease in your grease fitting when you are done playing in the snow. Other than that lock'em if you got'em and have fun and be safe.
Destruct O
Rockcrawlintoy
air down air down air down. nothin like mashin through 3 feet of powder with 3 psi. other then that make sure you are in the right gear, and when you start to get stuck stop and back up.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Quote from: Rockcrawlintoy on December 26, 2006, 09:00:52 PM
Good info, but what about for those of us who think powder is an urban legend?
Quote from: cruzila on December 22, 2006, 08:51:41 AM
just do this
The phrase "holy :pokinit:, batman!" comes to mind!  I thought for sure he was gonna kiss that rock wall!
