Author Topic: question about swapping full width axles  (Read 1672 times)
mcg_916
  • Member since Oct '06
« on: Nov 11, 2006, 03:40:16 PM »
is it possible to cut off the spring perches(on the axle) and move them towards the center more to fit the toyota spring location? i don't see why people would use a wider spring hanger and offset shackles if moving the spring perches is cheaper and not much harder to do so i think i am missing something important
and also, a friend of mine has a ford 9" rear axle that he will give me but he told me that all ford rear diffs are offset? if this is true how are some people using them? i apologize if these are dumb questions, im a noob :dunno:
Dooner
  • Turtle Points: 217
  • Male Posts: 769
  • Member since Feb '05
  • Invest in precious metal
Re: question about swapping full width axles
« Reply #1 on: Nov 11, 2006, 04:42:47 PM »
Your right, moving spring perches would be much easier than relocating shackles and hangers. The problem with some front axles is that there isnt room to move the perch inward due to the diff being in the way. This means you either outboard your shackles and hangers or build your perches so one of them is up onto the side of your diff housing. I thought Ford 9" rear ends were centered, but with 5 lug axles, meaning you'd need custom axles or wheel adapters to match up to Toyota pattern.
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
- Sales Employee -
freds40
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
« Reply #2 on: Nov 11, 2006, 05:04:12 PM »
On the front axles, the passenger side spring perch is cast as part of the center chunk. If you want to keep the stock width of the Toy, you need to cut down the driver side (long side) roughly 4-4.5" and then you can add the driver perch to gain the proper spring mount width.
On the 9", the center chunk is offset to compensate for the pinion favoring the passenger side. To line the pinion up with a centered tranny/t-case output, the chunk is offset. Shouldn't affect you and is how it was set up from the factory. If you want to have a centered third, you can cut down the driver side tube so that another passenger side shaft will fit in it's place. IIRC this will narrow the axle 3 or 4". It's an old hot rodders trick to narrow a 9" for cheap.
"between projects"
Last post Mar 22, 2005, 12:08:32 PM
by UNBREAKABLE
Last post May 26, 2006, 12:13:35 PM
by pickemup81
Last post Jan 07, 2007, 12:39:31 PM
by Shamb
Last post Nov 09, 2007, 10:15:57 PM
by Thomas P
Last post Apr 27, 2008, 09:32:14 PM
by kneedownnate
